Plugin to Setting timer to be viewed by all and specifically for moderators to follow- up topics
We need a developer to find a way in which as a moderator I can view all the deadlines and follow-up on topics in a way that each topic will have a specific deadline and if it passes the deadline the date is turned to red
For example: Bookmark is highly useful individually to follow-up posts but not for everyone.
How are the deadlines defined?
Maybe something that adds a “needs-attention” tag and then turns those red, perhaps just for moderators?
We need it to be defined by using date and colors to be set in a specific date and in blue color and if it ends to be in red color showing the same date for all the know which assigned topic is not completed since we already use the assigned plugin
Adding the date as a tag is also possible for everyone not only moderators
So you’re taking about assigned topics with the assign plugin? You want moderators to see assigned topics that haven’t been competed?
Do you have a budget?
yes, we are using the plugin to assign topics for each member where there’s a specific deadline but we are unable to fulfill it
for example in Google tasks for each task there’s an assignee and date
No budget is decided
I don’t see anything in assign about a deadline. How are your deadlines defined in discourse?
Is your budget in the range of $50, $500, or $5000? This will affect both what solutions are available and whether it’s worth the time to figure out what any of them might be.
It’s not defined we need to add this requirement for a smooth workflow
The budget is $300 maximum
We would like to have a plugin or any other solution that will help us manage the topics
