Stalwart-mail+Discourse: POP3 EOF reached (again)
Continuing the discussion from POP3 Polling SSL Issue:
Hello,
I am testing the new Stalwart-mail POP3 support with Discourse…
DNS records are complete
DNS Records
Type	Name	Contents
MX	hack2o.eu.	10 mx.z7l.eu.
CNAME	mail.hack2o.eu.	mx.z7l.eu.
TXT	202406e._domainkey.hack2o.eu.	v=DKIM1; k=ed25519; h=sha256; p=J7kVdkoSKjwJcdPOcqCvvR7YtJV3LtOKEQ09c00+/fY=
TXT	202406r._domainkey.hack2o.eu.	v=DKIM1; k=rsa; h=sha256; p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAuvXE8Nf0Q9C+/coc9RgACmoTwQ9OZMkJIuWxtT0fYr6UY3CYnjzOLp+VEKoqQA2OHfNM7Q3rQSw0ghjKcMW2OqzQKQAQTGrm3hvSjsJgQvUcgjHbZngpzfqBsCun6iONGuO33UJmzH4hpnm0ljLGiOw4wv6MA918wL71oZS7HWjYU9g31uasCVBpt0Ch1U6Vfs4/ejVSXbmvNb+BDQUU48E8SnpnZS6yLoMC7gByflVvoOlLvj8tV4HYdO74FXej4gUEUUacQUQPyWKDzHhhcuhG/nmoWOrbJyiTpoq4cflKTblg6wriBZ6XPXud2Og1U0SB1yPyEtV7q3b4ZLJ1AwIDAQAB
TXT	hack2o.eu.	v=spf1 mx ra=postmaster -all
SRV	_imaps._tcp.hack2o.eu.	0 1 143 mx.z7l.eu.
SRV	_imaps._tcp.hack2o.eu.	0 1 993 mx.z7l.eu.
SRV	_pop3s._tcp.hack2o.eu.	0 1 995 mx.z7l.eu.
SRV	_submissions._tcp.hack2o.eu.	0 1 465 mx.z7l.eu.
SRV	_submissions._tcp.hack2o.eu.	0 1 587 mx.z7l.eu.
CNAME	autoconfig.hack2o.eu.	mx.z7l.eu.
CNAME	autodiscover.hack2o.eu.	mx.z7l.eu.
CNAME	mta-sts.hack2o.eu.	mx.z7l.eu.
TXT	_mta-sts.hack2o.eu.	v=STSv1; id=16222476092926415687
TXT	_dmarc.hack2o.eu.	v=DMARC1; p=reject; rua=mailto:postmaster@hack2o.eu; ruf=mailto:postmaster@hack2o.eu
TXT	_smtp._tls.hack2o.eu.	v=TLSRPTv1; rua=mailto:postmaster@hack2o.eu
TLSA	_25._tcp.mail.hack2o.eu.	3 0 1 22eaf4d577f42a1ceeda1b8da12ab2c0eb20351b7e3f7035c2cac7dd700a3ab6
TLSA	_25._tcp.mail.hack2o.eu.	3 0 2 16c04cca276b0d880b843f35b8f8513b7b4157907cb19c5d5f36464ea5e04972e863f24a6cb18bcd39fe5cc0cff793d6a5225d8937654ab28b2c7096a12cd858
TLSA	_25._tcp.mail.hack2o.eu.	3 1 1 0a47742e724fe771934bbf9a5d9c721cf34b97135242042b9e0a2c030c634455
TLSA	_25._tcp.mail.hack2o.eu.	3 1 2 ab60f26c194e0467bade96dd1a0bffd5d465065b2740e577f28f889a019ec2b455af8b8a1b1bcd66b998bba91469c5c5430c0a9f52f27316b33f93997d48f3e7
TLSA	_25._tcp.mail.hack2o.eu.	2 0 1 76e9e288aafc0e37f4390cbf946aad997d5c1c901b3ce513d3d8fadbabe2ab85
TLSA	_25._tcp.mail.hack2o.eu.	2 0 2 afab698cbbbf892ebb555e09175056c1d4630fe7c350f44dcc6e71843d3b290df00d30ab4e356b630c69169d7633788338922fb637cf5b9f7be20a413eeaa518
TLSA	_25._tcp.mail.hack2o.eu.	2 1 1 d016e1fe311948aca64f2de44ce86c9a51ca041df6103bb52a88eb3f761f57d7
TLSA	_25._tcp.mail.hack2o.eu.	2 1 2 f8a2b4e23e82a4494e9998fcc4242bef1277656a118beede55ddfadcb82e20c5dc036dcb3b6c48d2ce04e362a9f477c82ad5a557b06b6f33b45ca6662b37c1c9
The POP3 account works fine with Thunderbird, and its configuration is nicely auto-discovered.
But Discourse fails to activate it, despite the TLS 1.3 workaround
Error message
Message
EOFError (end of file reached)
app/services/email_settings_validator.rb:55:in `validate_pop3'
lib/validators/pop3_polling_enabled_setting_validator.rb:35:in `authentication_works?'
lib/validators/pop3_polling_enabled_setting_validator.rb:15:in `valid_value?'
lib/site_settings/type_supervisor.rb:284:in `validate_value'
lib/site_settings/type_supervisor.rb:165:in `to_db_value'
lib/site_setting_extension.rb:368:in `add_override!'
lib/site_setting_extension.rb:609:in `block in setup_methods'
lib/site_setting_extension.rb:435:in `public_send'
lib/site_setting_extension.rb:435:in `set'
lib/site_setting_extension.rb:448:in `set_and_log'
app/controllers/admin/site_settings_controller.rb:56:in `update'
app/controllers/application_controller.rb:422:in `block in with_resolved_locale'
app/controllers/application_controller.rb:422:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
lib/middleware/anonymous_cache.rb:393:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:14:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/request_tracker.rb:289:in `call'
Backtrace
/usr/local/lib/ruby/3.3.0/net/protocol.rb:237:in `rbuf_fill'
/usr/local/lib/ruby/3.3.0/net/protocol.rb:199:in `readuntil'
/usr/local/lib/ruby/3.3.0/net/protocol.rb:209:in `readline'
net-pop (0.1.2) lib/net/pop.rb:1000:in `recv_response'
net-pop (0.1.2) lib/net/pop.rb:996:in `get_response'
net-pop (0.1.2) lib/net/pop.rb:984:in `block in quit'
net-pop (0.1.2) lib/net/pop.rb:1016:in `critical'
net-pop (0.1.2) lib/net/pop.rb:984:in `quit'
net-pop (0.1.2) lib/net/pop.rb:603:in `do_finish'
net-pop (0.1.2) lib/net/pop.rb:533:in `start'
net-pop (0.1.2) lib/net/pop.rb:316:in `auth_only'
actionpack (7.0.8.4) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.0.8.4) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (7.0.8.4) lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack (7.0.8.4) lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport (7.0.8.4) lib/active_support/callbacks.rb:118:in `block in run_callbacks'
i18n (1.14.5) lib/i18n.rb:351:in `with_locale'
activesupport (7.0.8.4) lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport (7.0.8.4) lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack (7.0.8.4) lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack (7.0.8.4) lib/action_controller/metal/rescue.rb:23:in `process_action'
actionpack (7.0.8.4) lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport (7.0.8.4) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.0.8.4) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (7.0.8.4) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.0.8.4) lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack (7.0.8.4) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.0.8.4) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (7.0.8.4) lib/abstract_controller/base.rb:151:in `process'
actionview (7.0.8.4) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:115:in `block in profile_method'
actionpack (7.0.8.4) lib/action_controller/metal.rb:188:in `dispatch'
actionpack (7.0.8.4) lib/action_controller/metal.rb:251:in `dispatch'
actionpack (7.0.8.4) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.0.8.4) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.0.8.4) lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
actionpack (7.0.8.4) lib/action_dispatch/routing/mapper.rb:48:in `serve'
actionpack (7.0.8.4) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (7.0.8.4) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (7.0.8.4) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.0.8.4) lib/action_dispatch/routing/route_set.rb:852:in `call'
rack (2.2.9) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.9) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.9) lib/rack/head.rb:12:in `call'
actionpack (7.0.8.4) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
rack (2.2.9) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.9) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (7.0.8.4) lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack (7.0.8.4) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/show_exceptions.rb:29:in `call'
logster (2.19.1) lib/logster/middleware/reporter.rb:40:in `call'
railties (7.0.8.4) lib/rails/rack/logger.rb:40:in `call_app'
railties (7.0.8.4) lib/rails/rack/logger.rb:27:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/request_id.rb:26:in `call'
rack (2.2.9) lib/rack/method_override.rb:24:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.9) lib/rack/sendfile.rb:110:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/host_authorization.rb:131:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:334:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
railties (7.0.8.4) lib/rails/engine.rb:530:in `call'
railties (7.0.8.4) lib/rails/railtie.rb:226:in `public_send'
railties (7.0.8.4) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.9) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.9) lib/rack/urlmap.rb:58:in `each'
rack (2.2.9) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
Env
HTTP HOSTS: forum.hack2o.eu
The error can be reproduced with pure Ruby Net::POP3, but authentication does not fail. It’s just an meaningless OpenSSL error. Connecting with openssl c_client directly works for both TLS1.2 and TLS1.3. I’m not sure what to do here, since everything seems to be working outside of the OpenSSL warning at the moment of disconnection.
Here is a minimal Ruby test:
Net::POP3 test
require 'net/pop'
puts "Testing POP3 connection for #{ENV['POP3_USER']} on #{ENV['POP3_HOST']}"
Net::POP3.enable_ssl
pop = Net::POP3.new(ENV['POP3_HOST'], 995)
print " using SSL: ", pop.use_ssl?? "yes":"no", "\n"
begin
  pop.auth_only(ENV['POP3_USER'], ENV['POP3_PASS'])
  puts "Authentication succeeded!"
rescue Net::POPAuthenticationError => err
  puts "Authentication failed."
#  p ENV['POP3_USER']
#  p ENV['POP3_PASS']
#  p pop
  exit
Note that I also tested setting ssl_params for enable_ssl with:
  • min_version: OpenSSL::SSL::TLS1_3_VERSION
  • max_version: OpenSSL::SSL::TLS1_2_VERSION
with the same results.
Here is an OpenSSL session (identical with both TLS1.2 and 1.3):
openssl s_client -quiet -tls1_3 mail.example:995
depth=2 C = US, O = Internet Security Research Group, CN = ISRG Root X1
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = E5
verify return:1
depth=0 CN = mail.example
verify return:1
+OK Stalwart POP3 at your service.
USER user@mail.example
+OK user@mail.example is a valid mailbox
PASS redacted
+OK Authentication successful
QUIT
40771049E17F0000:error:0A000126:SSL routines:ssl3_read_n:unexpected eof while reading:../ssl/record/rec_layer_s3.c:303:
openssl s_client -quiet -tls1_2 mail.example:995
verify return:1
verify return:1
verify return:1
PASS redacted
QUIT
I wonder what makes other implementations not bleed the OpenSSL error.
I think this is a bug with Stalwart-mail and will report them to this topic for review.
I couldn’t find where you reported this to stalwart, so I reported it here: [bug]: discourse pop3 polling doesn't work · Issue #567 · stalwartlabs/mail-server · GitHub
