Problem check 'missing_mailgun_api_key' error
Two users, Don and RBoy, are experiencing errors after updating to the latest version of Discourse, specifically the ‘missing_mailgun_api_key’ error. Don suspects the issue is related to a recent commit and his SMTP settings address being smtp.eu.mailgun.org instead of smtp.mailgun.org. RBoy also reports seeing the error in the logs, despite not using the Mailgun API. ted thanks the users for reporting the issue and mentions that a fix is available in a pending pull request, which should resolve the error once merged.
Hello :wave:
I’ve just updated today to the latest version and got some of the following errors in /logs.
TypeError (String does not have #dig method) app/services/problem_check/missing_mailgun_api_key.rb:8:in `dig' app/services/problem_check/missing_mailgun_api_key.rb:8:in `call' app/models/problem_check
info
app/models/problem_check.rb:58:in `call'
app/models/admin_dashboard_data.rb:36:in `block in problems'
app/models/admin_dashboard_data.rb:36:in `each'
app/models/admin_dashboard_data.rb:36:in `flat_map'
app/models/admin_dashboard_data.rb:36:in `problems'
app/models/admin_dashboard_data.rb:147:in `fetch_problems'
app/controllers/admin/dashboard_controller.rb:29:in `problems'
app/controllers/application_controller.rb:423:in `block in with_resolved_locale'
app/controllers/application_controller.rb:423:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
lib/middleware/anonymous_cache.rb:393:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:26:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/request_tracker.rb:236:in `call'
backtrace
actionpack (7.0.8.1) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.0.8.1) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack (7.0.8.1) lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:118:in `block in run_callbacks'
i18n (1.14.4) lib/i18n.rb:322:in `with_locale'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack (7.0.8.1) lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/rescue.rb:23:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport (7.0.8.1) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.0.8.1) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (7.0.8.1) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.0.8.1) lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.0.8.1) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (7.0.8.1) lib/abstract_controller/base.rb:151:in `process'
actionview (7.0.8.1) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:115:in `block in profile_method'
actionpack (7.0.8.1) lib/action_controller/metal.rb:188:in `dispatch'
actionpack (7.0.8.1) lib/action_controller/metal.rb:251:in `dispatch'
actionpack (7.0.8.1) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.0.8.1) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.0.8.1) lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
actionpack (7.0.8.1) lib/action_dispatch/routing/mapper.rb:48:in `serve'
actionpack (7.0.8.1) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (7.0.8.1) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (7.0.8.1) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.0.8.1) lib/action_dispatch/routing/route_set.rb:852:in `call'
rack (2.2.8.1) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.8.1) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.8.1) lib/rack/head.rb:12:in `call'
actionpack (7.0.8.1) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
rack (2.2.8.1) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.8.1) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack (7.0.8.1) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/show_exceptions.rb:29:in `call'
logster (2.19.1) lib/logster/middleware/reporter.rb:40:in `call'
railties (7.0.8.1) lib/rails/rack/logger.rb:40:in `call_app'
railties (7.0.8.1) lib/rails/rack/logger.rb:27:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/request_id.rb:26:in `call'
rack (2.2.8.1) lib/rack/method_override.rb:24:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.8.1) lib/rack/sendfile.rb:110:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/host_authorization.rb:131:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:334:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
railties (7.0.8.1) lib/rails/engine.rb:530:in `call'
railties (7.0.8.1) lib/rails/railtie.rb:226:in `public_send'
railties (7.0.8.1) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.8.1) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.8.1) lib/rack/urlmap.rb:58:in `each'
rack (2.2.8.1) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `<main>'
I think this commit is related with this.
https://github.com/discourse/discourse/commit/ea5c3a3bdc529db59be54c27588e41c7951ea269
If I understand it correctly here
There is no problem if the smtp_settings address is smtp.mailgun.org. My address is smtp.eu.mailgun.org. Maybe this is why I got the errors… :thinking:
Thanks :slightly_smiling_face:
After upgrading to 3.3.0 beta 1 I’m seeing these errors in the error logs
Message (4 copies reported)
config/initializers/008-rack-cors.rb:14:in `call'
Backtrace
Env
HTTP HOSTS: xxx.com
No settings have changed, not using mailgun api (don’t have it configured).
Thanks for the report, @Don and @RBoy! :pray:
The fix is here. Once merged the error should go away.
https://github.com/discourse/discourse/pull/26206
This topic was automatically closed after 18 hours. New replies are no longer allowed.
