So you want to set up Discourse locally to hack on and develop with?
This root guide links all the dev-install guides for the various systems to setup Discourse locally on. If you want to add a guide to this list, be sure to tag it dev-install before editing this post to include it here.
(If you want to install Discourse for production use, see our install guide)
In no particular order, here are the install guides for setting Discourse up on your local environment:
- Beginners Guide to Install Discourse on Ubuntu for Development
- Beginners Guide to Install Discourse on macOS for Development
- Beginners Guide to Install Discourse on Windows 10 for Development
- Beginners Guide to Install Discourse for Development using Docker
- Setting up Discourse for development on Fedora
This document is version controlled - suggest changes on github.
