Update to Require Category Copy
סיכום מבוסס בינה מלאכותית
The discussion revolves around an update to the “Require Category Copy” feature. debryc suggests adding tips on how to select a category, including an arrow image, and keeping the category selection menu highlighted when someone clicks on the compose box. They also propose a friendlier copy: “Select a category before typing here.” codinghorror agrees with the idea of using fewer words and updates the copy accordingly. However, they are hesitant to add a unicode arrow (↑) to the copy, considering it too much. The topic of keeping the category selection menu highlighted is noted as a minor consideration for @joffreyjaffeux to review.
Currently, the Require Category Copy is “You must select a category before typing here”.
See details on Require category selection before writing topic - #14 by jomaxro
I suggest adding tips on how to select a category.
Perhaps by including an arrow image like this is enough.
At minimum, I suggest keeping the highlight on the category selection menu if someone clicks on the compose box.
is a lot better than
Finally, I’d love the copy to be friendlier as well. Perhaps having
is sufficient. I especially like that it’s an action, instead of simply information.
4 לייקים
Oh you completely had me at less words. I’ll make it so!
You must Select a category before typing here.
Focus wise I am not sure that is up to @j.jaffeux
4 לייקים
Wonderful! What do you think about having an arrow, too, or keeping the category drop-down menu highlighted even when someone clicks on the compose window?
Screenshot%20of%20Google%20Chrome%20(5-2-19%2C%209-16-21%20PM)
לייק 1
It’s possible to add a unicode arrow but that feels a bit much to me
↑ Select a category before typing here.
לייק 1
This is the part that you might think about @j.jaffeux but it is relatively minor
3 לייקים
This topic was automatically closed after 31 hours. New replies are no longer allowed.
