No, there isn’t. As Justin mentioned above you can shorten that part of the URL whilst sharing, it as long as the number afterwards isn’t affected. URLs can’t be edited, nor can the means in which they are generated.
Looking by that title, First Impressions could be a tag, or a category.
There just needs to be something between the /t/ and the /999.
Perhaps we should omit the slug automatically in the share link pop-up thing, or have an option for it at least. As a comparison YouTube share links are very short as well and don’t include any slug info. This way only the share links are short, but the default urls in the browser address bar still have the title info and is probably good for seo.
I swear this used to be the case, but not longer seems necessary:
Edit: apparently for the same site it is necessary! If you click on it now it will just show a blank page! But for external links it works just fine. So probably best to just include a - in between
You seem to be unhappy that long titles are . . . long. You could stop people from making titles that are so long. See site setting max topic title length.
An option, maybe, but the slug is really useful for someone who sees the URL and is deciding whether to click it. That’s why it’s there!
Careful, this is risky, isn’t it? As I recall, we do some kind of hacky “best guess” to see if the slug is a number but the correct short form is always
https://forum.example.com/t/-/1999
and not
https://forum.example.com/t/1999
This is mostly a defense against bad linking when URLs get arbitrarily truncated, I don’t think it should be actively promoted as a feature to people?
