HTTPS works perfectly, but HTTP URL displays NGINX welcome page and doesn't redirect
I’ve recently installed Discourse to a Ubuntu Focal Fossa VPS and it works great, however I’m struggling to overcome some URL peculiarities.
The following is the behaviour I am seeing (in Safari). I have A NAME records for @, WWW and * created in with my registrar.
example.com [displays Welcome to nginx! page] FAIL
www.example.com [redirects to https://example.com] PASS
http://example.com [displays Welcome to nginx! page] FAIL
http://www.example.com [redirects to https://example.com and works fine] PASS
https://example.com [works as expected, doesn't redirect] PASS
https://www.example.com [errors with 'This Connection is Not Private' browser message] FAIL
I would like my installation to be at the root/apex so I entered example.com at setup.
Any advice graciously received!
Are you running an external nginx in the Discourse server? Why?
Discourse already ships with a pre-configured nginx that will handle that provided you let it listen to the 80 and 443 ports.
Hi @Falco, thank you for your reply. Not to my knowledge no, the image from the VPS provider is just called “Focal Fossa Clean OS” which I assume means it contains no third party tools.
This is just straight out of the box using the “30 minute” install route published.
sudo su
wget -qO- https://get.docker.com/ | sh
git clone https://github.com/discourse/discourse_docker.git /var/discourse
cd /var/discourse
./discourse-setup
Ohh that is a really weird behavior then!
Can you share your app.yml here (remove the sensitive data like passwords). The file lives at /var/discourse/containers/app.yml.
Also the docker ps -a output.
Sure thing, thank you. Would my domain having a weird TLD cause any issues? (it’s a .community).
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
params:
  db_shared_buffers: "768MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 8
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: example.com
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: ‘email@gmail.com'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: smtp.postmarkapp.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: username
  DISCOURSE_SMTP_PASSWORD: “password”
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  #DISCOURSE_SMTP_DOMAIN: discourse.example.com    # (required by some providers)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  LETSENCRYPT_ACCOUNT_EMAIL: email@gmail.com
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## The maxmind geolocation IP address key for IP address lookup
  ## see https://meta.discourse.org/t/-/137387/23 for details
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
and
CONTAINER ID   IMAGE                 COMMAND        CREATED          STATUS          PORTS                                      NAMES
465fbf1c3fb8   local_discourse/app   "/sbin/boot"   47 minutes ago   Up 46 minutes   0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp   app
Maybe this distro your provider give you comes with pre-installed nginx ?
What does curl -I localhost prints?
HTTP/1.1 301 Moved Permanently
Server : nginx/1.18.0
Date : Mon, 25 Jan 2021 20:18:00 GMT
Content-Type : text/html
Content-Length : 169
Connection : keep-alive
Does this mean it was already installed? (sorry I’m a n00b at this)
That is the exact expect response when it’s working. So, is http://example.com still showing nginx welcome page?
https://example.com is working just fine, but http://example.com (HTTP) goes off to the Welcome to nginx! page :sob:
Can you share the actual domain?
Sooo, that doesn’t give me the nginx welcome page at all.
Can you try it on another device like your phone?
curl -I example.com -L
Server: nginx/1.18.0
Date: Mon, 25 Jan 2021 20:35:21 GMT
Content-Type: text/html
Content-Length: 169
Connection: keep-alive
HTTP/2 200
server: nginx
date: Mon, 25 Jan 2021 20:35:22 GMT
content-type: text/html; charset=utf-8
vary: Accept-Encoding
x-frame-options: SAMEORIGIN
x-xss-protection: 1; mode=block
x-content-type-options: nosniff
x-download-options: noopen
x-permitted-cross-domain-policies: none
referrer-policy: strict-origin-when-cross-origin
x-discourse-route: finish_installation/index
cache-control: no-cache, no-store
content-security-policy: base-uri 'none'; object-src 'none'; script-src https://example.com/logs/ https://example.com/sidekiq/ https://example.com/mini-profiler-resources/ https://example.com/assets/ https://example.com/brotli_asset/ https://example.com/extra-locales/ https://example.com/highlight-js/ https://example.com/javascripts/ https://example.com/plugins/ https://example.com/theme-javascripts/ https://example.com/svg-sprite/; worker-src 'self' https://example.com/assets/ https://example.com/brotli_asset/ https://example.com/javascripts/ https://example.com/plugins/
x-request-id: 8755d4fa-387f-4509-8709-b6075f274d09
x-runtime: 0.026020
strict-transport-security: max-age=31536000
Ok well I’m clearly a moron. Tried on my phone over 4G (to check local DNS), all those URLs worked fine. Reconnected to WiFi, all work fine. So I then cleared the cache of Safari on the desktop and boom — everything works there too.
It must have been from when I was initially testing the host and the cache hasn’t flushed since. Thank you so much for your help to troubleshoot and sorry for taking up your time.
fwiw I just ran into this same issue today with Ubuntu 22.04. Clearing Safari cache and refreshing also fixed the issue.
