Can I customize the welcome message shown when creating a new topic based on the chosen tag or category?
In a Support discussion titled Can I customize the welcome message shown when creating a new topic based on the chosen tag or category?, jenrj asks if the “Welcome” message displayed when creating a new topic can dynamically change based on the selected category or tag — for example, prompting users to specify their mobile OS if they choose the “Mobile” category. pfaffman suggests that while all text in Discourse can be customized, it’s not inherently dynamic per category. Jagster confirms this limitation, noting the welcome message is static, but points to Discourse Templates as a possible workaround. mcwumbly clarifies that templates require manual selection and wouldn’t provide immediate, conditional feedback upon category selection — suggesting instead a theme-component might be needed. Alternatively, they recommend using the built-in Topic Templates feature per category to pre-fill the composer with relevant guidance. jenrj acknowledges the feedback and plans to explore Topic Templates for their use case. In summary, while Discourse doesn’t natively support dynamic welcome messages per category, Topic Templates offer a practical, albeit less immediate, solution for category-specific guidance.
Is it possible to customize the “Welcome” message on the right of the dialog that you see when you create a new Topic so that the text changes based on what category (or possibly tag) someone selects with their post? For example: if someone selects “Mobile” as a category, could I customize the text on the right to remind the Community member to include what OS they’re using with their mobile device? Thanks!
You can Customize all text in Discourse.
No you can’t that way, because wellcome is same to everyone everywhere.
But could this help:
I’m not sure that Discourse Templates would help here as it requires a user to actively select a pre-existing template whereas I understand what is needed here is to provide immediate feedback to the user once a category is chosen for their new topic.
To conditionally replace the text that shows up on the right, I think it’d require implementing a theme-component or similar.
One option would be to use the built in “Topic Templates” feature for the category, to pre-fill the composer with some text to fill in or replace: Using topic templates for categories
Yes, I was looking to provide immediate feedback to the user once they select a category for their new topic. I’ll look into the Topic Templates and see what we can do with them. Thanks a lot!
