Using the DModal API to render Modal windows (aka popups/dialogs) in Discourse
Discourse 3.1.0.beta6 ships with a brand new <DModal> component-based API. DModal is part of the UI kit and is imported from discourse/ui-kit/d-modal.
:information_source: This supersedes the old controller-based API, which is now deprecated. If you have existing modals using the old APIs, check out the migration guide here.
Rendering a Modal
Modals are rendered by including the <DModal> component in a handlebars template. If you don’t already have a suitable template, check out Using Plugin Outlet Connectors from a Theme or Plugin.
A simple modal would look something like this:
<DButton
  @translatedLabel="Show Modal"
  @action={{fn (mut this.modalIsVisible) true}}
{{#if this.modalIsVisible}}
  <DModal @title="My Modal" @closeModal={{fn (mut this.modalIsVisible) false}}>
    Hello world, this is some content in a modal
  </DModal>
{{/if}}
:information_source: The mut helper is used here as a hbs-only way to set a value. You could also set modalIsVisible using any other standard Ember method.
This example will create a simple Modal like this:
Wrapping in a component
Before introducing any more complexity, it’s usually best to wrap up your new Modal in its own Component definition. Let’s move the <DModal> stuff inside a new <MyModal /> component
// components/my-modal.gjs
<template>
  <DModal @title="My Modal" @closeModal={{@closeModal}}>
  </DModal>
</template>
Upgrading this .gjs file to a class-based component will allow you to introduce more complex logic and state.
To make use of the new component, update the call site to reference it, making sure to pass in a @closeModal argument.
<DButton
  <MyModal @closeModal={{fn (mut this.modalIsVisible) false}} />
{{/if}}
Adding a footer
Many modals have some kind of call-to-action. In Discourse these tend to be located at the bottom of the modal. To make this possible, DModal has a number of ‘named blocks’ which can have content rendered inside them. Here’s the example updated to include two buttons in the footer, one of which is our standard DModalCancel button
  <:body>
  </:body>
  <:footer>
    <DButton class="btn-primary" @translatedLabel="Submit" />
    <DModalCancel @close={{@closeModal}} />
  </:footer>
</DModal>
Rendering a modal from a non-hbs context
Ideally, <DModal> instances should be rendered from within an Ember template using the declarative technique demonstrated above. If that’s not feasible for your use case, it can be done by injecting the modal service and calling modal.show().
Make sure you’ve wrapped up your modal in its own component as described above. Then, trigger the modal by passing a reference of your component class to showModal:
import MyModal from "discourse/components/my-modal";
// (inject the modal service in the relevant place)
// Add this call whenever you want to open the modal.
// A `@closeModal` argument will be passed to your component automatically.
this.modal.show(MyModal);
// Optionally, pass a '`model`' parameter. Passed as `@model` to your component.
// This can include data, and also actions/callbacks for your Modal to use.
this.modal.show(MyModal, {
  model: { topic: this.topic, someAction: this.someAction },
// `modal.show()` returns a promise, so you can wait for it to be closed
// It will resolve with the data passed to the `@closeModal` action
const result = await this.modal.show(MyModal);
More customizability!
<DModal> has a number of named blocks and arguments.
Arguments
Arg Purpose
@closeModal Required for dismiss UI to appear at all.
@title Renders <h1 id="discourse-modal-title">; wires aria-labelledby.
@subtitle Small text below the title.
@flash / @flashType Inline alert at top of modal (DFlashMessage).
@hideHeader, @hideFooter Hide whole regions.
@headerClass, @bodyClass Extra class on header/body wrappers.
@dismissable Default true when @closeModal set. Disables Esc / backdrop click / X.
@autofocus Default true. Auto-focuses first focusable element via dTrapTab.
@submitOnEnter Default true. Enter clicks .d-modal__footer .btn-primary unless focus is in a form / textarea / select-kit.
@beforeClose async ({ initiatedBy }) => boolean. Return false to cancel close (e.g. dirty-form confirm).
@hidden Pauses keyboard handling; used when a nested modal is on top.
@tagName "div" (default) or "form". Use "form" for forms so native submit works.
Blocks
Block Position When to use
default / :body Main content area Default area
:aboveHeader Very top, before header Rarely needed; for content that must sit above the title bar (e.g. a banner).
:headerAboveTitle Inside header, before title Present but unused. Rarely needed.
:belowModalTitle Inside .d-modal__title, after the <h1> Excellent position for supplementary meta info.
:headerBelowTitle Inside header, after title block Tabs, sub-nav, or search input that’s part of the header.
:headerPrimaryAction Right side of header on mobile only Replaces the X close button with a primary action (e.g. “Save”). Also auto-renders a “Cancel” button on the left and adds .--has-primary-action to the header.
:belowHeader Between header and body Persistent sub-header content (e.g.searchar) that’s outside the scrollable body, so sticky display.
:aboveFooter Between body and footer Suppressed when @hideFooter is set. Use for content tied to the footer but outside it. Also rare.
:footer Bottom action bar Primary + secondary buttons. The first .btn-primary here is what Enter triggers.
:belowFooter After the footer Rarely needed; ignores @hideFooter. Useful for status text outside the bordered footer area.
Sources: the interactive styleguide for arguments, and the d-modal template implementation for named blocks.
CSS
Use the .d-modal classes as an anchor to override core, and avoid the legacy `.modal selector.
4 modifiers available:
  • .--large sets max width to 800px (desktop-only)
  • .--max sets max width to 90vw (desktop-only)
  • .has-search sets fixed height (80vh): intended for modals with search/filter system to avoid height change based on result length (desktop-only)
  • .--stacked sets footer buttons to stacking (mobile-only)
This document is version controlled - suggest changes on github.
A post was split to a new topic: Can I show a modal from head_tag
