Custom embedded replies
Install this theme component
Hello :wave:
It makes unified how the embedded replies handle on the desktop and mobile view.
Desktop
Mobile
Change Replies button text to show only the count on desktop view.
Go to admin/customize/site_texts and search for
js.post.has_replies.one delete Reply
js.post.has_replies.other delete Replies
There is a theme setting where you can translate the Jump to post button.
Screenshot 2023-07-24 at 19.26.51
This is very nice, I think it’s worth considering as the default. Better than the existing boxes in my opinion.
Agreed. If I can nitpick: I’d make the line align left of the reply dropdown to gain some extra space (mainly on mobile).
For sure an improvement over the boxes :heart:
Hello. I have installed this theme component a long time ago.
But just comparing it I realized that I don’t have buttons for “share”, “flag” and “reply”. I only have “Jump to post” button. Can you tell me how to set it up?
Hi @wenqin :wave: Maybe you need to conifigure the admin-settings-post menu and share links settings?
but unless I am misunderstanding you, it looks like you have them already
here
Oh those look like a screen photo of the footer buttons being used in a post on @Don’s test forum in theme creator. I don’t believe those are real buttons below the replies. They are for a sample post here:
If you scroll up to the OP and look at the replies, you will see how it is embedded.
thanks.I can’t believe it’s not a real button. :exploding_head: :exploding_head: :exploding_head:
I personally don’t use quora. but I really like quora like this. You can continue to reply to what others have replied to. And all the replies are displayed below the original one. Do we have any plugin that can implement such a reply feature?
The only thing I can think of with similar embeded replies within replies is the Discourse Journal plugin by Pavilion. It allows selecting a Journal topic which then allows embedded comments on replies that have their own pseudo-timelines.
https://github.com/paviliondev/discourse-journal
I suspect this one wasn’t updated anymore. It’s a must for engaging non-technical users on trivial topics to give them confidence.
This is what my instance shows after trying to enable the component:
Error: Undefined mixin. ╷ 58 │ @include sticky; │ ^^^^^^^^^^^^^^^ ╵ theme-entrypoint/mobile.scss 58:7 @import /var/www/discourse/mobile.scss 3:9 root stylesheet
The author has said he needs more interest & sponsoring in the plugin.
I believe Post Voting also does something similar but imho the Journal plugin may have some better options.
Confirmed
It would need to be tested. But if you are looking to mimic journal plugin in that only do to speak Op can post/reply with others only being able comment. Using topic voting with restricted replies may work.
Though iirc I think the journal pluginsu allow ppl to reply to other comments.
Hey Don, any chance this will be updated for the recent changes?
[Admin Notice] Theme ‘Custom Embedded Replies’ contains code which needs updating. (id:discourse.post-stream-widget-overrides) (learn more)
Hello :waving_hand:
This theme component is in the core now.
However the main difference is it…
Which means for now — it isn’t open the top embedded reply when you click the reply to tab but jumps to the post. This function cause the admin notice you see. Is this the function you want to use? Sure, I can modernize it to work with glimmer post stream but maybe we should put it in a separate theme component?
