I installed the Discourse AI plugin, setup Gemini and enabled a few modules, Summarization, Sentiment, Related Topics, AI Search and Toxicity.
At first it worked great, the Summarization button showed up and generated the content.
As soon as I enabled the Sentiment and Toxicity options, the Summarization stopped working, as in the button for Summarization disappeared from all topics. The sentiment tab on the dashboard shows no data to display.
When I look at the discourse logs, I see these errors:
Message
Job exception: ERROR: must be owner of database discourse
Backtrace
rack-mini-profiler-3.3.0/lib/patches/db/pg.rb:110:in `exec'
rack-mini-profiler-3.3.0/lib/patches/db/pg.rb:110:in `async_exec'
mini_sql-1.5.0/lib/mini_sql/postgres/connection.rb:202:in `run'
mini_sql-1.5.0/lib/mini_sql/active_record_postgres/connection.rb:38:in `block in run'
mini_sql-1.5.0/lib/mini_sql/active_record_postgres/connection.rb:34:in `block in with_lock'
activesupport-7.0.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
activesupport-7.0.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
activesupport-7.0.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
activesupport-7.0.8/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
mini_sql-1.5.0/lib/mini_sql/active_record_postgres/connection.rb:34:in `with_lock'
mini_sql-1.5.0/lib/mini_sql/active_record_postgres/connection.rb:38:in `run'
mini_sql-1.5.0/lib/mini_sql/postgres/connection.rb:181:in `exec'
/var/www/discourse/plugins/discourse-ai/lib/embeddings/vector_representations/base.rb:154:in `create_index!'
/var/www/discourse/plugins/discourse-ai/lib/embeddings/vector_representations/base.rb:71:in `block in consider_indexing'
/var/www/discourse/plugins/discourse-ai/lib/embeddings/vector_representations/base.rb:49:in `each'
/var/www/discourse/plugins/discourse-ai/lib/embeddings/vector_representations/base.rb:49:in `consider_indexing'
/var/www/discourse/plugins/discourse-ai/app/jobs/scheduled/embeddings_backfill.rb:38:in `execute'
/var/www/discourse/app/jobs/base.rb:297:in `block (2 levels) in perform'
rails_multisite-5.0.0/lib/rails_multisite/connection_management.rb:82:in `with_connection'
/var/www/discourse/app/jobs/base.rb:284:in `block in perform'
/var/www/discourse/app/jobs/base.rb:280:in `each'
/var/www/discourse/app/jobs/base.rb:280:in `perform'
/var/www/discourse/app/jobs/base.rb:351:in `perform'
mini_scheduler-0.16.0/lib/mini_scheduler/manager.rb:122:in `process_queue'
mini_scheduler-0.16.0/lib/mini_scheduler/manager.rb:70:in `worker_loop'
mini_scheduler-0.16.0/lib/mini_scheduler/manager.rb:59:in `block (2 levels) in ensure_worker_threads'
Iām sorry but Iām going to have a draw a blank on this one. I simply followed the instructions on this topic (and the other AI module topics), install the plugin, rebuild discourse and configure it from the admin page.
I didnāt see any step regarding configuring user permissions. Did I miss a step or could this be some exception scenario not handled in the install/build script?
Looks like the database user on self-hosted installs lack the permissions to set this. A better way to set this is being tracked upstream, letās wait for a fix there for a bit before trying to handle it
Thanks for the update Falco. Could you please let me know what features or the impact of this and/or if itās related to the log errors or some AI functionality that wontā work; that I way I know what to expect or what wonāt be working and can I need to temporarily disable those features to avoid other issues which may arise from this error.
EDIT: It looks like that number of probes being calculated based on the number of items in the database. Wondering if this could be set during a rebuild (so while the database may grow over time, each time discourse if upgraded, will optimize it until thereās a run time fix). Temporarily, at runtime check if there are SUPERUSER permissions before trying to alter it.
