I18n keys showing on Webhooks edit page
I’m seeing this on the Webhooks edit page with 3.3.0.beta1-dev:
Two of the sections and their checkbox labels appear to be showing i18n keys instead of the values of those keys. E.g., I’m fairly sure that
[en.admin.web_hooks.voting_event.group_name]
is not the intended header for whatever category that’s supposed to be.
Good catch!
You are not supposed to see the webhook of plugin that is not installed on your Discourse.
This is a regression from here:
Specifically here.
The symbols provided in TYPES don’t match the list values:
To the team, here is a possible solution:
def self.types_with_prefix(prefix)
  TYPES.select { |key, _value| key.to_s.start_with?(prefix.to_s) }.values
def self.active
  ids_to_exclude = []
  unless defined?(SiteSetting.solved_enabled) && SiteSetting.solved_enabled
    ids_to_exclude.concat(types_with_prefix(:solved))
  unless defined?(SiteSetting.assign_enabled) && SiteSetting.assign_enabled
    ids_to_exclude.concat(types_with_prefix(:assign))
  unless defined?(SiteSetting.voting_enabled) && SiteSetting.voting_enabled
    ids_to_exclude.concat(types_with_prefix(:voting_topic))
  unless defined?(SiteSetting.chat_enabled) && SiteSetting.chat_enabled
    ids_to_exclude.concat(types_with_prefix(:chat_message))
  self.where.not(id: ids_to_exclude.flatten)
Thank you for reporting this issue :confetti_ball:
I fixed it today with in this PR
This topic was automatically closed after 2 days. New replies are no longer allowed.
