Ajouter de nouveaux webhooks et personnaliser la charge utile du webhook
Ever wonder how to add new webhook types? Or how to reduce the payload? Here is the tutorial for the plugin authors. It demos how to add the session and user notification event types as well as customization to the payload. You can also check the plugin on GitHub while reading.
If you’d like to have a new webhook type supported by the team, bring up a feature request instead.
Before started, make sure you already understand webhook guide.
New webhook event type
A new webhook event type is defined in the database so that Ember client and webhook can find relevant information.
1.Seeding
Add a seed file in the following path of the plugin db/fixtures/001_custom_web_hook.rb.
WebHookEventType.seed do |b|
  b.id = 100 # start with a relative large number so it doesn't conflict with the core type
  b.name = "notification"
  b.id = 101
  b.name = "session"
Then putting SeedFu.fixture_paths << Rails.root.join("plugins", "discourse-webhooks-example", "db", "fixtures").to_s into the plugin.
Admin dashboard needs the text to display the new event type. Adding them in config/locales/client.<language-code>.yml:
en:
  admin_js:
    admin:
      web_hooks:
        notification_event:
          details: "When there is a new notification."
        session_event:
          details: "When there is a login or logout."
2. Connect with the internal DiscourseEvent or hook on your own
add_model_callback(:notification, :after_commit, on: :create) do
  # you can enqueue web hooks anywhere outside the AR transaction
  # provided that web hook event type exists
  WebHook.enqueue_hooks(:notification, # event type name
                        notification_id: self.id, # pass the relevant record id
                        # event name appears in the header of webhook payload
                        event_name: "notification_#{Notification.types[self.notification_type]}_created")
%i(user_logged_in user_logged_out).each do |event|
  DiscourseEvent.on(event) do |user|
    WebHook.enqueue_hooks(:session, user_id: user.id, event_name: event.to_s)
3. Final step: Sidekiq Jobs
Adding a new method to the Jobs::EmitWebHookEvent:
Jobs::EmitWebHookEvent.class_eval do
  # the method name should always be setup_<event type name>(args)
  def setup_notification(args)
    notification = Notification.find_by(id: args[:notification_id])
    return if notification.blank? # or raise an exception if you like
    # here you can define the serializer, you can also create a new serializer to prune the payload
    # See also: `WebHookPostSerializer`, `WebHookTopicViewSerializer`
    args[:payload] = NotificationSerializer.new(notification, scope: guardian, root: false).as_json
  def setup_session(args)
    user = User.find_by(id: args[:user_id])
    return if user.blank?
    args[:payload] = UserSerializer.new(user, scope: guardian, root: false).as_json
An aside note, the payload is sent as if you are an administrator browsing a Discourse site. Be careful for what you sent.
Payload customization
There are two ways to reduce the payload size.
  1. Define a custom serializer.
  2. Uses plugin filter.
The first one is explicit to do. The second one involves a plugin API where you have the power to modify the payload. This enables the possibility to slice the JSON, i.e. @Lapinot suggested.
Plugin::Filter.register(:after_build_web_hook_body) do |instance, body|
  if body[:session]
    body[:user_session] = body.delete :session
  body # remember to return the object, otherwise the payload would be empty
Final aside note, a {{plugin-outlet name="web-hook-fields"}} is now available in the web hook configuration page.
The plugin code is available under GitHub - erickguan/discourse-webhooks-example · GitHub.
Thanks @erlend_sh to encourage me writing this tutorial and @tgxworld for sorting out the internals.
26 « J'aime »
@fantasticfears Note that it isn’t recommended to run migrations in plugins. Instead I’ve updated the howto to create a fixture file that will automatically be run when db:migrate is invoked.
7 « J'aime »
Fixture is better than migration but it doesn’t work with the plugin now. The plugin system includes only db/migrate but not fixture.
Ah ha I forgot to include the secret sauce.
10 « J'aime »
I didn’t know there’s a new API register_seedfu_fixtures! Updated.
8 « J'aime »
what do i have to do to make it just notification webhook and remove the session event ?
Can someone offer a hint here?
I need to submit this JSON payload when a new user is created:
{"email_address":"address of new user", "status": "subscribed"}
I guess I don’t know how to create a serializer.
This is easy.
class MySerializer < ApplicationSerializer
  attributes :email_address, :status
my_object = MyClass.new(email_address: "address of new user", status: "subscribed")
MySerializer.new(my_object).as_json
4 « J'aime »
@fantasticfears Thanks for the writeup!
It needs a bit of tweaking to take account of the changes introduced in this commit.
  • You no longer need a setup_ method in Jobs::EmitWebHookEvent.
  • There’s now a WebHook a class method for formatting custom payloads via a serializer:
    WebHook.enqueue_object_hooks(type, object, event, Serializer)
Also, I’m wondering about the thinking behind namespacing the payload with the event type? This makes it a little harder to use endpoints you don’t fully control, which expect certain attributes in the body.
def build_web_hook_body(args, web_hook)
   if ping_event?(event_type)
     body[:ping] = 'OK'
   else
     body[event_type] = args[:payload]
2 « J'aime »
Can you help me update the guide?
This is mainly for possible extension. Additional information can be serialized to other keys. But we relies on serializers now so it’s more or less useless.
2 « J'aime »
@fantasticfears
Bonjour.
J’essaie de connecter Discourse à APP en utilisant des webhooks.
J’ai fait la plupart des choses, mais il ne reste qu’une seule chose.
Lorsque vous créez un nouveau sujet dans Discourse, vous envoyez une charge utile qui contient de nombreux paramètres à APP.
Cependant, Slack ne reçoit que le paramètre « text ». Je veux donc personnaliser la charge utile lors de l’utilisation de webhooks.
Comment puis-je modifier la charge utile lors de l’utilisation de webhooks dans Discourse ?
ACTUELLEMENT
  "post": {
    "id": 19,
    "name": "user",
    "username": "user",
    "avatar_template": "/letter_avatar_proxy/v2/letter/u/c0e974/{size}.png",
    "created_at": "2018-07-20T06:24:33.205Z",
    "cooked": "<p>Cool, now i have you, haha</p>",
    "post_number": 6,
    "post_type": 1,
    "updated_at": "2018-07-20T06:24:33.205Z",
    "reply_count": 0,
    "reply_to_post_number": null,
    "quote_count": 0,
    "avg_time": null,
    "incoming_link_count": 0,
    "reads": 0,
    "score": 0,
    "topic_id": 11,
    "topic_slug": "this-is-new-topic",
    "topic_title": "This is new topic",
    "display_username": "user",
    "primary_group_name": null,
    "version": 1,
    "user_title": null,
    "moderator": false,
    "admin": true,
    "staff": true,
    "user_id": 1,
    "hidden": false,
    "trust_level": 1,
    "deleted_at": null,
    "user_deleted": false,
    "edit_reason": null,
    "wiki": false,
    "topic_posts_count": 6
À VENIR
Cordialement.
Salut, j’essaie de créer un webhook personnalisé en suivant ce guide et cet exemple de plugin, mais je n’arrive pas à faire apparaître mes nouveaux types d’événements personnalisés dans l’interface utilisateur du webhook. J’ai essayé d’installer le plugin lié dans ce guide sur mon instance de développement locale et les événements de cet exemple de plugin n’apparaissent pas non plus. Je suppose que quelque chose a changé entre 2017 et maintenant, ce qui affecte cela ?
Quelqu’un ici sait comment faire fonctionner l’exemple de plugin dans ce sujet ? Je soupçonne que le problème pourrait être lié au code d’initialisation de la base de données car les nouvelles entrées n’apparaissent pas dans la réponse de /admin/api/web_hooks. Tel qu’il est actuellement, ce guide n’est pas fonctionnel. Merci !
Salut ! Je pense que j’ai besoin d’aide
J’essaie d’ajouter un webhook personnalisé, ce que j’ai réussi à faire et il envoie correctement la charge utile à l’URL du webhook. La seule chose que je n’arrive pas à faire est d’activer l’événement lors de la configuration du webhook dans l’administration. J’ai suivi le tutoriel ci-dessus en enregistrant le fixture, mais il n’apparaît pas dans l’administration.
J’ai essayé de quelques manières :
SeedFu.fixture_paths << Rails.root.join("plugins", "<plugin_name>", "db", "fixtures").to_s
register_seedfu_fixtures(Rails.root.join("plugins", "<plugin_name>", "db", "fixtures").to_s)
Fixture :
    b.id = 101
    b.name = "remove_like"
J’ai également ajouté ceci à la locale :
en:
  js:
    plugin_name:
      placeholder: placeholder
    admin:
      web_hooks:
        remove_like_event:
          name: "Remove Like Event"
          details: "When a user marks a post as the accepted or unaccepted answer."
Est-ce que je manque quelque chose ? ou suis-je censé faire cela d’une autre manière ?
D’accord, il semble que ce soit un problème de cache ou quelque chose de similaire, car il est apparu lorsque je l’ai installé sur une autre instance de Discourse.
