Hello
When I open the keyboard on a modal input this will jumps the page to the top.
Android 10; CLT-L29 Build/HUAWEICLT-L29
Chrome 123.0.6312.80
Thank you
Hello
Thank you
I have similar issue in various spots like here if I shrink the keyboard to use search
With keyboard closed
With keyboard open search input is blind
keyboard will also block/cover up the form template editor and a few other spots.
There is another topic about that Android keyboard overlaps/interferes text edit fields
Yeah I see we have a couple topics on this issue. With oldest I think from March 22?
Don’s theme component doesn’t fix it in the form-templates
I think the issue in this topic is not about the keyboard covering something, but about you being taken to the top of a topic (list) when you use a modal.
They look like they might be at least in part related in some way maybe?
At least going by the video.
I also noticed the jump to the top after using AI explain. It’s quite annoying because you lose your reading position.
Yes,I have same problem
There is the same problem when typing in the flag modal, for Something Else or Illegal.
Thanks for reporting this, everyone — I’ve asked our team to fix this up!
