Тип поля пользователя «кликабельная ссылка» / URL
A user field type of link / URL that shows as a clickable link on user card, profile etc
As you can see, the URL’s are not clickable
Thank you
5 лайков
We do have the Custom Profile Link theme component, though the idea of adding a ‘link’ field type to the custom user fields themselves was also raised in that topic the other day too:
6 лайков
Thanks for your quick reply!
Ha! That’s interesting as I viewed that thread but only scrolled back up a little way, in fact I stopped just before those 2 posts :joy:
I used to use custom theme code to make the links clickable but then Ember updated and I had to scrap all the code
A dedicated user field type would be awesome for this if it’s at all possible
1 лайк
