j127
August 28, 2024, 9:49pm
1
I’ve set up Discourse Connect where I can log into another app with Discourse.
Everything works when I use passwords, but when I log in to Discourse with a passkey during the flow, I get a 500
error.
I see a 500 error in the NGINX logs:
POST /session/passkey/auth.json HTTP/2.0
and this in the Rails logs:
Started POST "/session/passkey/auth.json" for <ip_address> at 2024-08-28 21:33:32 +0000
Processing by SessionController#passkey_login as JSON
Parameters: {"publicKeyCredential"=>{"signature"=>"...", "clientData"=>"...", "authenticatorData"=>"...", "credentialId"=>"...", "userHandle"=>"..."}}
start
Completed 500 Internal Server Error in 30ms (ActiveRecord: 0.0ms | Allocations: 4837)
done
I’m not sure where else to look for an error message.
Is it a bug, or do I need to do something else to get passkeys to work with Discourse Connect ?
j127
August 31, 2024, 2:32am
Is anyone out there using DiscourseConnect who could quickly check if passkeys work with it on their site?
I’m going to have to figure out a completely different approach if passkeys don’t work with DiscourseConnect .
I actually can replicate the same failure, but it’s not specific to DiscourseConnect being in the flow.
My passkey login worked on meta.discourse.org but failed on our internal site.
What errors do you see in your tracebacks (/logs
I see:
NoMethodError (undefined method `ok' for false)
app/controllers/session_controller.rb:809:in `login'
app/controllers/session_controller.rb:399:in `passkey_login'
app/controllers/application_controller.rb:424:in `block in with_resolved_locale'
app/controllers/application_controller.rb:424:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
lib/middleware/anonymous_cache.rb:393:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:26:in `call'
lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:35:in `call_app'
lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:22:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/processing_request.rb:12:in `call'
lib/middleware/request_tracker.rb:360:in `call'
@dev-managers passkey login is partially broken
j127
August 31, 2024, 5:42am
5
Thanks for checking. Here’s what I see at /logs
actionpack (7.1.4) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.1.4) lib/abstract_controller/base.rb:224:in `process_action'
actionpack (7.1.4) lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack (7.1.4) lib/abstract_controller/callbacks.rb:259:in `block in process_action'
activesupport (7.1.4) lib/active_support/callbacks.rb:121:in `block in run_callbacks'
i18n (1.14.5) lib/i18n.rb:351:in `with_locale'
activesupport (7.1.4) lib/active_support/callbacks.rb:130:in `block in run_callbacks'
activesupport (7.1.4) lib/active_support/callbacks.rb:141:in `run_callbacks'
actionpack (7.1.4) lib/abstract_controller/callbacks.rb:258:in `process_action'
actionpack (7.1.4) lib/action_controller/metal/rescue.rb:25:in `process_action'
actionpack (7.1.4) lib/action_controller/metal/instrumentation.rb:74:in `block in process_action'
activesupport (7.1.4) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.1.4) lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport (7.1.4) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.1.4) lib/action_controller/metal/instrumentation.rb:73:in `process_action'
actionpack (7.1.4) lib/action_controller/metal/params_wrapper.rb:261:in `process_action'
activerecord (7.1.4) lib/active_record/railties/controller_runtime.rb:32:in `process_action'
actionpack (7.1.4) lib/abstract_controller/base.rb:160:in `process'
actionview (7.1.4) lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
actionpack (7.1.4) lib/action_controller/metal.rb:227:in `dispatch'
actionpack (7.1.4) lib/action_controller/metal.rb:309:in `dispatch'
actionpack (7.1.4) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.1.4) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:51:in `block in serve'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:131:in `block in find_routes'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:124:in `each'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:124:in `find_routes'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.1.4) lib/action_dispatch/routing/route_set.rb:882:in `call'
rack (2.2.9) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.9) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.9) lib/rack/head.rb:12:in `call'
actionpack (7.1.4) lib/action_dispatch/http/permissions_policy.rb:36:in `call'
rack (2.2.9) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.9) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/cookies.rb:689:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
activesupport (7.1.4) lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack (7.1.4) lib/action_dispatch/middleware/callbacks.rb:28:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
logster (2.20.0) lib/logster/middleware/reporter.rb:40:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/request_id.rb:28:in `call'
rack (2.2.9) lib/rack/method_override.rb:24:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.9) lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:191:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/remote_ip.rb:92:in `call'
railties (7.1.4) lib/rails/engine.rb:536:in `call'
railties (7.1.4) lib/rails/railtie.rb:226:in `public_send'
railties (7.1.4) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.9) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.9) lib/rack/urlmap.rb:58:in `each'
rack (2.2.9) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
pmusaraj
(Penar Musaraj)
September 3, 2024, 2:02pm
7
Thanks for the report @j127 , I can confirm this is an issue with DiscourseConnect and am working on a fix.
pmusaraj
(Penar Musaraj)
September 3, 2024, 8:44pm
9
j127
September 3, 2024, 9:37pm
10
Thank you for the fast response.
Edit: I just tested it, and it works here now.
pmusaraj
(Penar Musaraj)
Closed
September 7, 2024, 12:00pm
11
This topic was automatically closed after 3 days. New replies are no longer allowed.
