- enable DiscourseConnect
- Use the Install this Theme Component button
- Get a weird error message
Other variations are (depending on the discourse_connect_url)
Excon::Error::TooManyRedirects
Expected([200, 302]) <=> Actual(301 Moved Permanently)
Even if you’re already logged in? (since it’s you, I assume you thought of that, but it’s all I’ve got).
Yes - but apparently the plugin for this button makes a request from the backend of Meta to the forum, which is obviously not authenticated.
