Banner Featured Links
:information_source: Summary Banner Featured Links allows you to create a banner of links.
:eyeglasses: Preview Theme Creator
:hammer_and_wrench: Repository GitHub - Arkshine/discourse-banner-featured-links · GitHub
:question: Install Guide How to install a theme or theme component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Summary
It provides a wide range of customization options.
It’s a feature inspired by the fantastic “Meta Branded” Discourse theme.
Features
The default look – it uses the theme color.
The button can be styled separately:
You can place the links at various places via the plugin outlet setting.
A list of common locations is provided in the description.
:information_source: I recommend using the Developer Toolbar theme component to see where the plugin outlets are located!
For example, if you want to mimic the Meta Brand theme, use the search-banner-below-input outlet. It assumes you have installed the Search Banner component.
Details
The current style can be achieved with the following settings:
I encourage you to try your style!
Settings
General
Name Description
links Text links to be displayed in the header.
show_for_members Display the links for logged-in users.
show_for_anon Display the links for anonymous users.
display_on_mobile Display the links on mobile devices.
display_on_desktop Display the links on desktop computers.
display on homepage Displays the links on the homepage.
url must contain Enter paths that should display the banner. Add * to the end of the path as a wildcard.
plugin outlet The location to display the links.
Common Locationsabove-main-containerabove-site-headerafter-headerbefore-header-panelbefore-list-areabefore-topic-listbelow-site-headerheader-list-container-bottomtopic-above-post-stream
Search Banner component:
search-banner-below-headlinesearch-banner-below-input
links setting:
Name Description
Icon The FontAwesome icon or emoji to display for the links.
Shortcuts
Windows: Win + .
Mac: Cmd + Ctrl + Space
ChromeOS: Launch + Shift + Space
Title The title of the link.
URL The URL to link to.
Target Opens the linked document:
_blank: in a new window or tab (this is the default)
_self: in the same frame as it was clicked
_parent: in the parent frame
_top: in the full body of the window.
You can also style per-button. It will overwrite the global style.
Name Description
Width The width of the button.
Font The font of the button.
Rounding The amount of rounding to apply to the button.
Background The background color of the button.
Background Hover` The background color of the button when hovered.
Color` The text color of the button.
Color Hover` The text color of the button when hovered.
Border The border of the button.
Border Hover The border of the button when hovered.
Shadow The shadow of the button.
CSS Classname A custom CSS class to apply to the button.
Useful if you want to style the button differently and the settings are not enough.
You can target with .banner-featured-links__link.your-classname {}
Global Styling
Customize the default spacing and look of the links.
You can overwrite the button styling for each link individually.
Buttons Wrapper Styling
Customize the container of the links.
Name Description
buttons wrapper max width The maximum width of the buttons wrapper.
buttons wrapper margin The margin of the buttons wrapper.
mobile buttons wrapper max width The maximum width of the buttons wrapper on mobile.
mobile buttons wrapper margin The margin of the buttons wrapper on mobile.
Buttons Spacing & Text Font
Customize the spacing of the buttons and the font size of the text.
Name Description
buttons justify How to distribute space between and around links.
buttons gap The gap between the buttons.
buttons font The font of the buttons.
mobile buttons justify How to distribute space between and around links on mobile.
mobile buttons gap The gap between the buttons on mobile.
mobile buttons direction The direction of the buttons on mobile.
mobile buttons font The fpnt of the buttons on mobile.
Button Styling
Customize the default look of the buttons.
Name Description
button width The width of the button.
button padding The padding of the button.
button rounding The amount of rounding to apply to the button.
button background The background color of the button.
button background hover The background color of the button when hovered.
button color The text color of the button.
button colo hover The text color of the button when hover.
button border The border of the button.
button border hover The border of the button when hovered.
button shadow The shadow of the button.
Advanced Customization
You can use the following CSS to customize further:
.banner-featured-links {
  &__wrapper {
  &__wrapper-links {
  &__link {
If you provide a customization per button, you can provide a class name in the CSS Classname setting.
Then, you can target this way:
  &__link.myclass {
Useful links
Credits
  • Discourse for the idea, inspired by the amazing Meta Branded theme.
  • Don and nolo – They made an initial version; I took some of their ideas.
One meta comment to improve an otherwise good quality introduction of a component: a screenshot from a mobile. It would save time when choosing between usefulness, pros and cons.
Was this inspired the Meta Branded theme?
I think so :wink:
Must’ve skimmed it too much - I was looking at the ‘Credits’ section :laughing:
No worries. I’ve updated the credits section to make it clearer. Thanks!
I pushed a small fix if you installed the component the first time. :+1:
My last commit renamed a setting, but the default values were not updated.
Thanks to @manuel for reporting the issue!
Hi @Arkshine, thanks a lot for this plugin!
I’ve been using it for a while, but after adding another button today it broke the entire forum so it looks like this now:
Do you happen to know why this could happen?
Hey, does that mean if you remove this button, it doesn’t break?
Well, I had to contact the Discourse team to disable the plugin, so everything’s now back to normal, yeah.
Now I’m kind of hesitant to restore the old settings to test the theory :sweat_smile:
I understand, no worries. Sorry about that! You’re the first to have this issue.
Do you still remember what values you entered for the button? If I can reproduce it, that would be helpful!
Sure, thanks a lot for your help!
This is really weird, cuz I made changes not so long ago and it worked just fine.
I removed one of the buttons and added the new one:
Here are the logs, if it helps
[{“url”:“Topics tagged new-widget Widgets”,“target”:“_self”,“button_color_hover”:“#197bff”},{“url”:“Topics tagged In-Progress Progress”,“target”:“_self”,“button_color_hover”:“#197bff”},{“url”:“CSS Codes - Elfsight Community Codes”,“target”:“_self”,“button_color_hover”:“#197bff”},{“url”:“Ask the Community - Elfsight Community Recaps”,“target”:“_self”},{“icon”:“:trophy:”,“text”:"Join our Champion Program! ",“url”:“Elfsight Champion Program: Help us grow our community forum! - Announcements - Elfsight Community”}]
Previous: [{“url”=>“Topics tagged new-widget”, “icon”=>“:fire:”, “text”=>“New Widgets”, “target”=>“_self”, “button_color_hover”=>“#197bff”}, {“url”=>“Topics tagged In-Progress”, “icon”=>“”, “text”=>“In Progress”, “target”=>“_self”, “button_color_hover”=>“#197bff”}, {“url”=>“CSS Codes - Elfsight Community”, “icon”=>“”, “text”=>“CSS Codes”, “target”=>“_self”, “button_color_hover”=>“#197bff”}, {“url”=>“Ask the Community - Elfsight Community”, “icon”=>“”, “text”=>“Support”, “target”=>“_self”, “button_color_hover”=>“#197bff”}, {“url”=>“Elfsight Champion Program: Help us grow our community forum! - Announcements - Elfsight Community”, “icon”=>“:trophy:”, “text”=>“Join our Champion Program! “, “target”=>”_self”}]
Thanks to @Helga_Razinkova’s help in PM, I was able to reproduce the issue.
I pushed a fix :+1:.
In short, the component was not expecting the settings to be updated through Settings Editor and with a missing icon field, an error happened.
This is brilliant! It is so comprehensive and customisable; you seem to have thought of pretty much everything.
I’ve noticed a minor bug where the icons aren’t visible at times.
This is what my links look like:
This is what happens when you:
  1. Use Chrome (haven’t tried other browsers sorry)
  2. Navigate away from a page with the Banner Featured Links
  3. Return to the page using the browser ‘Back’ button
You can demonstrate this yourself on ehealthforum.nz
Thanks Nathan! I’ve pushed a fix. Let me know if it still happens!
Wonderful!!! All fixed.
Got another minor (but disconcerting) UX bug:
The text on the buttons is still captured by the :visited pseudo class, meaning that the text color behaves strangely on hover once each link has been visited.
This is non-hover:
This is hover before visiting (both icon and text change)
This is hover after visiting (note that the icon changes but not the text)
@nathank Can you try to update and see if it’s better?
That was with an updated instance. There was one small PR on the Search Banner, but none on this TC to apply. Regardless, I did a rebuild. Still there!
It doesn’t show in incognito, I’m guessing because it doesn’t save my visted status.
Is this compatible with the AIR Theme to serve at top of the Community page with buttons linking to a wordpress?
Trying to place these under the search bar (like on this site) by using ‘search-banner-below-input’ for the “Plugin outlet” – went back and forth with the AI and it explained that now because the search is core and not an extension that location won’t work. Just wondering if that is correct.
