root@docker2:/var/discourse# ./launcher stop web_only && ./launcher rebuild data && ./launcher rebuild web_only
x86_64 arch detected.
+ /usr/bin/docker stop -t 600 web_only
web_only
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 data
data
./launcher: Zeile 334: Warnung: Kommandoersetzung: NULL-Byte in der Eingabe ignoriert.
2.0.20240825-0027: Pulling from discourse/base
Digest: sha256:6de68cb49198b5281f79ed9401b3fe818c854d220dcf0238549fe2f2adb19146
Status: Image is up to date for discourse/base:2.0.20240825-0027
docker.io/discourse/base:2.0.20240825-0027
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-10-04T15:54:02.326983 #1] INFO -- : Reading from stdin
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/cli.rb:54:in `split': invalid byte sequence in UTF-8 (ArgumentError)
split = conf.split("_FILE_SEPERATOR_")
from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/cli.rb:54:in `run'
from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/bin/pups:9:in `<top (required)>'
from /usr/local/bin/pups:25:in `load'
from /usr/local/bin/pups:25:in `<main>'
Any ideas how to fix this? My forum is currently unavailable after this re-deployment
In this case web_only and data are separated containers and the startup of the web_only container fails with
oot@docker2:/var/discourse# ./launcher start web_only
starting up existing container
+ /usr/bin/docker start web_only
Error response from daemon: Cannot link to a non running container: /data AS /web_only/data
Error: failed to start containers: web_only
Maybe I need to start manually through docker in this case as the database is external on another machine, see this code in the web_only yaml:
## connect to central postgres database
DISCOURSE_DB_SOCKET: ''
DISCOURSE_DB_USERNAME: discourse
DISCOURSE_DB_PASSWORD: xxxxxxxxxx
DISCOURSE_DB_HOST: 10.10.xx.xx
DISCOURSE_REDIS_HOST: data
Unless you’ve run a cleanup that deleted the container, in which case you’re likely in trouble.
Then I’m surprised to see the “cannot link” error. I’ve only seen that when it’s trying to use a docker link to talk to another container on the same machine.
Oh! Yeah, it’s the redis that it can’t connect to. You’ve got a data container with the redis in it, right? The destroy start should work with the given caveat.
@pfaffman thanks, that fixed it. I forgot that the data container also provides the redis caching functionality - but anyway, now the containers are running again.
What can we do with the bootstrap error from launcher script, line 334? I never saw this error before. Is the launcher_go/v2 ready to use as a replacement instead?
root@docker2:/var/discourse/containers# yamllint web_only.yml
web_only.yml
5:81 error line too long (115 > 80 characters) (line-length)
8:1 warning missing document start "---" (document-start)
14:4 warning missing starting space in comment (comments)
14:3 warning comment not indented like content (comments-indentation)
15:4 warning missing starting space in comment (comments)
18:81 error line too long (85 > 80 characters) (line-length)
36:3 warning comment not indented like content (comments-indentation)
37:4 warning missing starting space in comment (comments)
43:81 error line too long (85 > 80 characters) (line-length)
44:81 error line too long (87 > 80 characters) (line-length)
58:81 error line too long (84 > 80 characters) (line-length)
67:81 error line too long (90 > 80 characters) (line-length)
68:4 warning missing starting space in comment (comments)
77:81 error line too long (83 > 80 characters) (line-length)
79:4 warning missing starting space in comment (comments)
99:81 error line too long (81 > 80 characters) (line-length)
110:81 error line too long (81 > 80 characters) (line-length)
117:81 error line too long (81 > 80 characters) (line-length)
126:43 error trailing spaces (trailing-spaces)
151:4 warning missing starting space in comment (comments)
154:4 warning missing starting space in comment (comments)
155:4 warning missing starting space in comment (comments)
156:4 warning missing starting space in comment (comments)
156:81 error line too long (131 > 80 characters) (line-length)
