Thema's aanpassen zonder een knop voor code bewerken
Sometimes, you may want to customize a Discourse theme but find that there’s no “Custom code” section with an “Edit code” button available. This often happens with remote themes (themes installed from an external source) and the preinstalled themes (Horizon & Foundation). Here’s how you can still add your customizations:
Understanding the limitation
For preinstalled themes, you see a banner telling you
This theme is preinstalled and can not be deleted or customized
For remote themes, you’ll typically see a message like:
If you want to edit this theme, you must submit a change on its repository
:discourse2: Hosted by Discourse? Then you might see: “Editing of remote themes is disabled in Discourse. Please contact us if you need assistance transitioning customized remote themes to a local theme.”
Options for customization
  1. Submit changes to the main repository: If your changes could benefit others, consider proposing them to the theme’s original creators. This requires familiarity with git and GitHub.
  2. Create a copy (fork) of the repository: Create your own version of the theme’s code repository, add your customizations, and use your copied version. This method requires technical knowledge and means you’ll need to maintain updates yourself.
  3. Create a custom component: This method allows you to add customizations without modifying the original theme. It’s the recommended approach for most administrators and will be the focus in this guide.
Creating a custom component
Follow these steps to create a custom component for your theme customizations:
  1. Go to your site’s admin panel and navigate to /admin/config/customize/components
  2. Click the “Install” button at the top right
  3. Select “+ Create new”, enter a name for your component (e.g. “My custom component”), choose “Component” as the type, and click “Create”
  4. Find the newly created component in the list of components and click the “Edit” button
  5. Add the component to the theme(s) you want to customize
    :warning: Don’t forget to save by clicking the green check mark
  6. Click “Edit code”
  7. Add your customizations in the appropriate sections (CSS, <head>, etc.)
  8. Click “Save” to apply your changes
Important notes
  • Your customizations will be applied on top of the existing theme.
  • If the base theme updates, your custom component will still apply its changes, which might sometimes lead to unexpected results.
  • Always test your customizations thoroughly after theme updates.
By following these steps, you can add custom CSS, HTML, or other modifications to your Discourse theme without directly editing the remote theme files. This method is suitable for most administrators looking to make small customizations to their site’s appearance or functionality.
