Quick Search not available on Phone View
The searchable Users Field is only available with quick search,
and quick search is only available with Desktop view, not Phone view.
That means, there is no way to search Users Field on your phone, correct?
I’m not sure I follow. Do you want to search for users on mobile? You can do so from this dropdown:
I mean the User Field. Seems it is impossible to search User Fields on Phone View. @pmusaraj
That “Users” option in the dropdown should still work. Here’s an example from my local instance:
Do you have any idea what settings could block the User Fields searching (I have made the field searchable)?
Mine is a pretty new site with modifications only from “All Site Settings”
