Hoe zijn vermeldingen bedoeld om te werken?
Hi everyone,
Just noticed that the dropdown list of usernames doesn’t appear when you press “@” like it used to. It only pops up when you type in the first letter of a username.
Is it something that can be fixed? It was really convenient.
yes, you need to type a first letter … but I’m not sure if that changed …
It’s actually a regression, @renato is preparing a fix
this should be fixed now. I just tested on my site.
Awesome, thanks a lot! It’s all good now :slight_smile:
