Возможность включения указанных частных категорий в Годовой обзор
My use-case is a forum where there is an even split between public and private content.
I wish to (privately) share the yearly review, included both private and public content.
The limitation of 5 public categories really sucks for this use-case. I’ve had to set up a staging site, make it log-in only, and reset the category permissions to everyone for the (5) categories I want to include. As I’m not sure which are the busiest, I’ve done this for another 10.
Can’t we just make this plugin a little more flexible?
I’d love to be able to specify which categories (public or private), and have no limit on the number of categories. 5 most commonly used public categories is fine as a default, but it is just too restrictive much of the time.
2 лайка
I think there is already no limit. One post is created for each category that you add to the yearly review categories setting.
5 лайков
You are indeed correct! I’ve just run it with 16 categories and all good. It will even run on private categories!
I wish I knew this before embarking on this little journey. I’ll update the wiki description of the plugin topic (done).
5 лайков
