중복된 확장명 "wasm" 오류 해결 방법
Hi,
i changed Build to stable and run rebuild app and now the website shows oops and the nginx log:
nginx: [warn] duplicate extension "wasm", content type: "application/wasm", previous content type: "application/wasm" in /etc/nginx/conf.d/discourse.conf:4
supervisor pid: 53 unicorn pid: 85
Any idea to solve this?
Thanks
Unless you were on a version older than the current stable, you can’t do that.
Hi Jay,
ok i switch back and rerun rebuild and discourse worked again. I read in the forum and it seems that i understand the explanation wrong. So thanks now its clear.
Hi Jay,
i now switch back, have successfull updated to latest dev Version, reconfigure to stable and run rebuild and now i got the same error message. Any Idea?
Thx
Out of curiosity, why do you want to use the stable branch?
As I’m understanding Jay, the beta branch will always be more recent than stable, and you can’t go back to an older version of Discourse. Which may (or not) be the underlying cause of the error you have :thinking:
Hi,
i understand it in a different way. Look: Switch from beta to stable releases. So it should possible, right?
It is, but you have to wait for the release of 3.4.0
You cannot switch to stable until the next stable release.
Just to be sure, you meant beta, nod dev?
On another test installation, the Installation of Discourse is with no Version configured. The UI shows Version 3.4.0.beta3-dev is running, the Updater shows now 3.4.0.beta3, which i understand is the stable version. I find this Is Discourse always in "beta"? - #23 by kwinz and i now understand that this is the normal behavior with dev and beta3. So if you have no other information, i am fine with this.
