Problema con il ripristino di Discourse da backup (3.4, database abbastanza grande)
Hi there,
We are one of your early bird users, we are using Discourse since 2015.
It works just fine until latest update with Postgres update included (possibly 3.4?). We have one backup points before this update. We decide to make clean install then restore from this backup.
OS: Ubuntu 24.04.1 LTS (latest updates) + docker 26.1.3
Trying to restore large discourse backup (44GB, single site) to a blank container.
Automated restore fails on DB migration with following error:
PG::DuplicateColumn: ERROR: column “notification_level” of relation “user_chat_channel_memberships” already exists (PG::DuplicateColumn)
logs:
Specifically, the migration stops after deploying the SQL archive because a column in the database is not unique.
column "notification_level" of relation "user_chat_channel_memberships" already exists
Summary
ALTER TABLE
ALTER TABLE
ALTER TABLE
ALTER TABLE
ALTER TABLE
Migrating the database…
EXCEPTION: /var/www/discourse/lib/discourse.rb:139:in `exec’: Failed to migrate database.
rake aborted!
StandardError: An error has occurred, all later migrations canceled: (StandardError)
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in exec' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in async_exec’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:56:in block (2 levels) in raw_execute' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:1004:in block in with_raw_connection’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/concurrency/null_lock.rb:9:in synchronize' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:976:in with_raw_connection’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:55:in block in raw_execute' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/notifications/instrumenter.rb:58:in instrument’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:1119:in log' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:54:in raw_execute’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:538:in internal_execute' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:137:in execute’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/query_cache.rb:27:in execute' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:48:in execute’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/schema_statements.rb:629:in add_column' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/schema_statements.rb:418:in add_column’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration/default_strategy.rb:10:in method_missing' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1059:in block in method_missing’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1025:in block in say_with_time' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/benchmark-0.4.0/lib/benchmark.rb:304:in measure’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1025:in say_with_time' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1048:in method_missing’
/var/www/discourse/plugins/chat/db/migrate/20241003122030_add_notification_level_to_user_chat_channel_memberships.rb:10:in up' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:997:in public_send’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:997:in exec_migration' /var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in block in exec_migration’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/benchmark-0.4.0/lib/benchmark.rb:304:in measure' /var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in exec_migration’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:978:in block (2 levels) in migrate' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/benchmark-0.4.0/lib/benchmark.rb:304:in measure’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:977:in block in migrate' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:415:in with_connection’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:976:in migrate' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1190:in migrate’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1538:in block in execute_migration_in_transaction' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1591:in ddl_transaction’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1537:in execute_migration_in_transaction' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1512:in each’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1512:in migrate_without_lock' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1457:in block in migrate’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1609:in with_advisory_lock' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1457:in migrate’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1264:in up' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1239:in migrate’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/tasks/database_tasks.rb:262:in migrate' /var/www/discourse/lib/tasks/db.rake:259:in block (2 levels) in ’
/var/www/discourse/lib/distributed_mutex.rb:53:in block in synchronize' /var/www/discourse/lib/distributed_mutex.rb:49:in synchronize’
/var/www/discourse/lib/distributed_mutex.rb:49:in synchronize' /var/www/discourse/lib/distributed_mutex.rb:34:in synchronize’
/var/www/discourse/lib/tasks/db.rake:234:in block in <main>' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in <top (required)>’
Caused by:
ActiveRecord::StatementInvalid: PG::DuplicateColumn: ERROR: column “notification_level” of relation “user_chat_channel_memberships” already exists (ActiveRecord::StatementInvalid)
Caused by:
Tasks: TOP => db:migrate
/var/www/discourse/lib/discourse.rb:173:in execute_command' /var/www/discourse/lib/discourse.rb:139:in exec’
/var/www/discourse/lib/discourse.rb:35:in execute_command' /var/www/discourse/lib/backup_restore/database_restorer.rb:153:in migrate_database’
/var/www/discourse/lib/backup_restore/database_restorer.rb:28:in restore' /var/www/discourse/lib/backup_restore/restorer.rb:61:in run’
script/discourse:191:in restore' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/command.rb:28:in run’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/invocation.rb:127:in invoke_command' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor.rb:538:in dispatch’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/base.rb:584:in start' script/discourse:345:in <top (required)>’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:58:in load' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:58:in kernel_load’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli/exec.rb:23:in run' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:455:in exec’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/command.rb:28:in `run’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in invoke_command' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor.rb:527:in dispatch’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:35:in dispatch' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/vendor/thor/lib/thor/base.rb:584:in start’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/cli.rb:29:in start' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/exe/bundle:28:in block in <top (required)>’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/lib/bundler/friendly_errors.rb:117:in with_friendly_errors' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/exe/bundle:20:in <top (required)>’
/usr/local/bin/bundle:25:in load' /usr/local/bin/bundle:25:in ’
Trying to rollback…
Rolling back…
Cleaning stuff up…
Dropping functions from the discourse_functions schema…
Removing tmp ‘/var/www/discourse/tmp/restores/default/2025-01-09-180715’ directory…
Unpausing sidekiq…
Marking restore as finished…
Notifying ‘system’ of the end of the restore…
Finished!
[FAILED]
4 Mi Piace
Come correggere un file SQL in modo che db:migrate venga eseguito correttamente?
2 Mi Piace
Su quale commit si trova il vecchio sito?
Ci sono state un paio di regressioni in cui un commit includeva una migrazione che non avrebbe dovuto. La mia ipotesi è che questo sia uno di quei casi.
2 Mi Piace
Hai esattamente lo stesso set di plugin su entrambe le istanze?
Su quale commit si trova la tua installazione di Discourse esistente e su quale commit del plugin chat?
1 Mi Piace
Apprezzo il tuo gentile coinvolgimento. Il dump SQL è di 45 GB, ci vuole un’eternità per lavorarci.
Ho provato a eseguire l’aggiornamento della GUI il 31 dicembre che ha bloccato la migrazione del DB. Il vecchio sito è sparito dal 6 gennaio, tutto ciò che ho è il dump SQL e i caricamenti multimediali salvati. Sto cercando di avviare un nuovo sito e ripristinare il mio DB lì. Sto eseguendo solo pochi plugin nel mio YAML:
1 Mi Piace
Qual è il nome del file di backup? (Contiene informazioni sull’ultima migrazione eseguita)
1 Mi Piace
sitename-2025-01-06-033732-v20240912212253.sql.gz
Durante il ripristino manuale, sono stati segnalati i seguenti problemi (potrebbero significare qualcosa anche questi):
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842596361: ERRORE: impossibile creare l’indice univoco "category_featured_topics_pkey"
DETTAGLIO: La chiave (id)=(14) è duplicata.
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842596928: ERRORE: impossibile creare l’indice univoco "incoming_links_pkey"
DETTAGLIO: La chiave (id)=(1) è duplicata.
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842596937: ERRORE: impossibile creare l’indice univoco "incoming_referers_pkey"
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842597117: ERRORE: impossibile creare l’indice univoco "post_hotlinked_media_pkey"
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842597378: ERRORE: impossibile creare l’indice univoco "sitemaps_pkey"
DETTAGLIO: La chiave (id)=(2) è duplicata.
psql:/shared/backups/default/da-stereo-2025-01-06-033732-v20240912212253.sql:842597693: ERRORE: impossibile creare l’indice univoco "upload_references_pkey"
DETTAGLIO: La chiave (id)=(8) è duplicata.
Quindi è interessante.
  • quei conflitti riguardano tabelle piuttosto banali e gli ID in conflitto sono bassi
  • il tuo backup risale a settembre e la migrazione column "notification_level" of relation "user_chat_channel_memberships" already exists è di ottobre, quindi non è stata eseguita sulla tua istanza precedente, ed è una delle prime migrazioni che viene eseguita dopo il ripristino.
Questo mi fa pensare che tu abbia un problema diverso. Si tratta di un’installazione standard? E la tua istanza precedente era un’installazione standard? Ho il sospetto che il backup non venga ripristinato nello schema corretto e che le migrazioni vengano eseguite su un’istanza vuota.
2 Mi Piace
SÏ, è una normale installazione di Docker e il mio sito originale è stato creato utilizzando questo manuale nel 2015.
C’è qualcosa che posso estrarre dalla console Postgres o Rails per fare luce su cosa sta succedendo?
Grazie,
Qualsiasi suggerimento, consiglio o indicazione sarĂ  molto apprezzato.
Intendi un backup di Discourse solo SQL o uno dump SQL che hai creato in altro modo?
Backup esclusivo di Discourse.
A casa, ho configurato PostgreSQL e il nostro backup dei dati è stato ripristinato quasi senza problemi.
Sembra che durante il ripristino del file in PostgreSQL (che si trova all’interno del container di Discourse), il vecchio database non venga eliminato, e questo causa un conflitto, impedendo la corretta distribuzione del backup.
Sembra quello che diceva Richard.
Ci sono stati alcuni commit relativi a postgres di recente, anche se non sono sicuro che siano stati accettati. Potresti provare a ricompilare prima di tentare di ripristinare di nuovo.
1 Mi Piace
Quando si ripristina un archivio sql.gz, si osserva quanto segue:
Copia dell’archivio nella directory temporanea…
Estrazione del file di dump…
Validazione dei metadati…
Versione corrente: 20241224191732
Versione ripristinata: 20240912212253
e ovviamente db:migration fallisce con l’errore segnalato nel post #1
Si osserva che il database postgres “discourse” è stato ripristinato con tutte le tabelle/dati richiesti al suo interno:
psql (13.18 (Debian 13.18-1.pgdg120+1))
Digita “help” per aiuto.
discourse=> \dn+
                                  Elenco degli schemi
        Nome         |   Proprietario   |       Privilegi di accesso       |      Descrizione
 backup              | discourse        |                                  |
 discourse_functions | discourse        |                                  |
 public              | discourse        | discourse=UC/discourse +         | schema pubblico standard
                     |                  | =UC/discourse                    |
(3 righe)
discourse=> discourse=> \l
                                  Elenco dei database
   Nome    |  Proprietario | Codifica |   Ordinamento   |    ctype    |       Privilegi di accesso
 discourse | postgres      | UTF8     | en_US.UTF-8     | en_US.UTF-8 | =Tc/postgres +
           |               |          |                 |             | postgres=CTc/postgres +
           |               |          |                 |             | discourse=CTc/postgres
 postgres  | postgres      | UTF8     | en_US.UTF-8     | en_US.UTF-8 |
 template0 | postgres      | UTF8     | en_US.UTF-8     | en_US.UTF-8 | =c/postgres +
 template1 | postgres      | UTF8     | en_US.UTF-8     | en_US.UTF-8 | =c/postgres +
(4 righe)
ma rake segnala che sta utilizzando il DB sbagliato:
rake db:version
database: discourse
Current version: 20241224191732
Come posso indicare a rake di puntare a 20240912212253?
Grazie
Questo è ciò che accade quando c’è un problema di permessi. Discourse gestisce gli schemi durante il ripristino e quando non ha i permessi per enumerare le tabelle nel database, le cose vanno male.
Anche se non l’ho mai sperimentato, potrebbe anche essere un problema con lo spazio su disco disponibile?
1 Mi Piace
Solo una sensazione: potrebbe esserci un timeout durante gli spostamenti delle tabelle dopo un ripristino?
Grazie per l’indizio.
Lo spazio su disco non è un problema; ho 6-7 volte più spazio della dimensione del DB. Posso provare un’importazione manuale prima di eseguire la migrazione e correggere i permessi. La domanda è, cosa esattamente deve essere concesso?
Penso che tu debba aggiornare lo script manuale in questo modo:
DROP SCHEMA public CASCADE;
CREATE SCHEMA public;
ALTER SCHEMA public OWNER TO discourse;
CREATE EXTENSION IF NOT EXISTS hstore;
CREATE EXTENSION IF NOT EXISTS pg_trgm;
END;
Non è necessario creare lo schema public (e impostare il proprietario), poichÊ le versioni piÚ recenti di Pg creano lo schema dal backup SQL dump.
Tuttavia, le autorizzazioni delle tabelle devono essere corrette per l’utente discourse, per impostazione predefinita sono postgres.
Ora funziona! Grazie a tutti per le idee e il supporto.
6 Mi Piace
