Subscriptions not displaying
The discussion Subscriptions not displaying started with zuker having troubles displaying the subscriptions button. pfaffman suggested checking the Stripe account activation, but zuker confirmed that the Stripe accounts seem to be syncing well. blake asked about the usage of a pricing table, and zuker replied that it’s not being used. blake mentioned that the “Subscribe” button only shows up for signed-in users. After some troubleshooting, blake identified the issue as the “Discourse subscriptions pricing table enabled” option being checked, which zuker confirmed was the problem and thanked blake for the help.
Hi
All the settings seems to be fine, but i can’t manage to display the subscriptions button here
s/subscriptions
Any ideas? Thanks
I also tried on your site, a standard install with the Subscription plugin added today.
There could be some new bug in the plugin, but I haven’t seen any other complaints, and the last update was 2 weeks ago.
Are you sure that your Stripe account is fully activated? Have you been using it for something else?
Yes. It seems a bug or something weird because the stripe accounts seems to be syncing well products with the admin page.
So are you using a pricing table then?
What is being displayed on that page?
No, im not using a price table. I created a product that’s synced with stripe
Okay cool. So subscriptions will load at just /s then.
The “Subscribe” button will only show up for signed in users.
When i try to enter /s it redirect me to the /s/subscriptions
That should only happen if “Discourse subscriptions pricing table enabled” is checked. Can you double check that it isn’t checked?
Thanks! That was the issue.
