many markdown editors allow to style the blockquotes with some keyword… like (in Obsidian Callouts - Obsidian Help )
> [!tip] Callouts can have custom titles
> Like this one.
since many of us are starting to sync content with Obsidian… is it possibile to have such a styling (apply a custom class) to the blockquotes?
i couldn’t find any reference here in the forum
Great idea!
A theme component could be a reasonable approach (it is easier to make versus editing or creating a Markdown plugin)
I just gave it a try quickly:
how could you make it so… fast! ![:slight_smile: :slight_smile:](https://emoji.discourse-cdn.com/twitter/slight_smile.png?v=12)
It’s not done; this is just a quick and basic preview.
I’m pretty sure there are issues (for example, nested quotes).
The Discourse API is super convenient; It’s easier than you think!
All that is left is essentially rearranging the generated HTML.
You might want to learn too: Introduction to Discourse Development! ![:smile: :smile:](https://emoji.discourse-cdn.com/twitter/smile.png?v=12)
Heliosurge
(Dan DeMontmorency)
5
There is also a Theme component that can round the corners of quotes
And one that customizes Solved Quite
Studying these as well as the link @Arkshine shared are great starting points. Also learning to use inspect element in your browser.
alehandrof
(Alex Armstrong)
6
Would this styling also be used in emails that are sent out?
