הפעלה של שינוי ניווט הנושא מונעת אינטראקציות באזור מסוים בעמוד
On mobile, the area to the right of the navigation toggle, at the same height that the navigation toggle, can’t be interacted, though the nav button is small and floating to the right of the screen.
It’s badly explained, so, here’s a screenshot. Tap anywhere on the purple area, it won’t do anything. You can try to like, show likes or reactions, copy link, show the replied post, etc… No interaction will work.
I mostly won’t notice it, but my thumb tends to move across this area, and having a “dead touch” from time to time, requiring me to scroll more, bugs me :bug:
6 לייקים
Thanks! this should fix it
https://github.com/discourse/discourse/pull/31135
4 לייקים
Thanks Kris :slightly_smiling_face: I think I won’t create a new topic for this, I’ve noticed after this change the .topic-navigation-outlet is not clickable. For example the .d-toc-wrapper. I added pointer-events: auto which fixed that.
2 לייקים
yes good catch, here I’m re-enabling pointer events on all children of the wrapper to avoid this: UX: ensure all children of `.with-topic-progress` are clickable by awesomerobot · Pull Request #31176 · discourse/discourse · GitHub
2 לייקים
