Users report that on mobile, tags in the topic list are not tappable, while categories are (a recent change), despite both being clickable in topic titles. md-misko notes this inconsistency is frustrating, as tapping tags often leads to opening the topic instead. Canapin confirms the bug. sam suggests overriding CSS via a theme component. md-misko tried the suggested CSS but found it ineffective until updating to the latest build, where categories work but tags still don’t. awesomerobot confirms regression and provides updated CSS: .topic-list .topic-item-stats__category-tags { .discourse-tag, .badge-wrapper { pointer-events: all; } }. They caution that small tap targets may lead to accidental taps, citing the 45px mobile UI guideline, and note redesigning for better tap zones would be a major change. md-misko counters that, on their sub-6” screen, tags are easy to tap—especially with the Clickable Topic Theme Component—and finds topic titles harder to tap due to left-aligned text and negative space. They argue consistency between topic list and topic title behavior is warranted.
Personally, I don’t find these elements too small on mobile. In fact, I tap on category and tags in the topic list frequently, only to find myself in the topic title instead, having to repeat the same action again, which finally brings me to the category/ tag view.
There are indeed links on tags in the mobile view, but clicking them won’t work.
Having the cursor and clicking on them sometimes opens the topic below:
I think the entire change by @awesomerobot is CSS overridable. Perhaps try a theme component on your site for a few weeks and report back with the CSS change you recommend?
I already tried this in a theme component using the above CSS, but it didn’t seem to work.
My production server is not updated to the latest version yet and both category and tags are not tappable there.
But I also tried this on staging using the latest build and something must have changed recently, because the category is tappable now, but the tags are not.
For consistency sake, would you agree that both elements serve similar functions and should work the same way out of the box?
Of course, I wouldn’t mind fixing this using the CSS, but it doesn’t seem to work for me (tried both on production and staging).
Hmm it seems something may have regressed… what I see now on iOS is that the categories tap through to the category page and the tags are a dead zone (so they don’t even click through to the topic). I can look into this. That CSS is also out of date… at the moment it would be (I’ll update that post):
I definitely understand the desire for consistency, but accidentally tapping on a category or tag instead of a topic, or tapping on the wrong category/tag is very easy… and it’s a particularly bad experience on the topic list where entering a topic is the primary action.
The minimum recommended size for a tappable element on a mobile device is generally around 45px square, and we’d have to nearly double the height of categories and tags to get there. This is possible if categories and tags are limited to a single line, but a lot of sites have enough content here for it to wrap… and spacing like this wouldn’t be great:
I could imagine redesigning categories and tags to use some kind of more button-like styling to ensure proper tap sizes, but that would be a big change that we’d want to implement throughout all of Discourse.
Thanks for the updated CSS, it works on the latest build.
Strangely, this is not my experience on mobile at all. Maybe it’s because of my right-handed use, but I always found it much more difficult to tap on the topic title than on any other elements.
I mostly use my right thumb to navigate around and it’s almost impossible to accidentally tap category and even tags most of the time, but tapping on the title itself sometimes is (because of the left alignment of text and line breaking due to narrow screen width there is mostly negative space on the right).
Fortunately, Clickable Topic Theme Component vastly improved navigation on mobile for me, where I’m now almost exclusively using the negative space in the topic list to navigate to the topic itself, and use the category and tag elements to quickly filter to category or tag view (only to be surprised, again and again, that it doesn’t work ).
I’m not sure if this is related to the screen size at all, but my mobile has a sub 6’’ screen and I never had any issues targeting those elements.
And when in the topic itself, there is even less spacing between the topic title and category and tag elements, and tapping them has alway been enabled there.
