如下图所示
rse
Hi there!
Is there an issue with the translation of those labels? I don’t speak your language, it would help if you could try and describe the problem in more detail, please. Thanks!
Ah, on second look: are you looking to add new/unread counts for the second site on your list? It should happen automatically, if you have connected that site.
可以正常显示。
没看到计数是因为没有新的事件。
抱歉占用了你们的宝贵时间。
