Discourse Gamification을 설치했는데 리더보드를 찾을 수 없습니다
On a self-hosted install with a default Theme I have installed the Discourse Gamification plugin but can’t see the leader board under the category. Any ideas?
I also installed Right sidebar block component to see if I can use that component to show it but no luck
Maybe it’s just not enabled? What do you see at /admin/plugins/discourse-gamification/settings?
Not enabled:
Enabled:
Can you manually navigate to /leaderboard/ on your site? What does it show?
yes its enabled
in Admin panel under leaderboard/1 I can see it but as a non-admin user on public site I can’t see it
Have you created a leaderboard yet? Hope are the permissions for it set up?
Go to /admin/plugins/discourse-gamification/leaderboards and configure the leaderboard visibility as you see fit.
Yes I have configured it but still won’t show.
