Кто-нибудь может сказать, это плагин или компонент темы? Почему я его не нашел
Can someone tell me if this is a plugin or a theme component? Why didn’t I find it
I don’t believe that is. It’s the default message shown to logged out users who have been browsing for a while.
2 лайка
This isn’t a plugin or theme component — it’s actually built-in core functionality of Discourse. When a visitor isn’t logged in and has browsed for a bit, the login/signup prompt is automatically shown. You don’t need to install anything extra — just make sure the Enable Signup CTA (“enable_signup_cta”) site setting is turned on.
4 лайка
While it’s a core feature, there is a component to override the requirements of when the banner is shown.
2 лайка
@vivilonger did those answers help you? I’m curious.. what are you wanting to change about the signup CTA feature?
Helpful, I’ve solved it, thank you very much @tobiaseigen
