Добавить значок за загрузку аватара
It would be a very nice incentive for people to add a profile picture if they would be granted a first-steps-badge when they do it the first time.
1 лайк
Adding a profile picture is part of the Autobiographer badge:
https://meta.discourse.org/badges/9/autobiographer
3 лайка
Hi, I am not sure this works, I have 159 users who do not use the default avatar (from data explorer) and 16 only that got the Autobiographer badge. Shoul’dnt they be 159 with the badge ?
1 лайк
I said having an avatar is part of the badge.
How many of the 159 users added information about them in the “about me” field in their profile?
Got it, avatar and profile data are two different things, but that means that badge does not answer the initial query ?
1 лайк
Firstly, it was a hint that there is already a badge that can be triggered when uploading an avatar. So if you want to add your own SQL-triggered badge, you might want to disable it so that the user doesn’t receive two at once. Secondly, you can use the query for the badge as an example to create a badge just for saving the avatar.
2 лайка
Very interesting source for querying, thanks !
