‘Powered by Discourse’ covers dropdown
Discourse footer brand covers dropdown. Not sure if it’s because Horizon theme.
Version: 2025.12.0-latest
Browser: Edge 142.0.3595.93
Could you try it in safe mode to see if it’s limited to the horizon theme?
And could you be more specific about which page this is on. I can’t quite work out what it is from the screenshot.
Ah, I think it might be the settings in the review queue.
It works fine in safe mode. So the bug is: the dropdown options are covered by powered by discourse in /review/settings when Horizon theme is enabled
@jordan.vidrine The powered-by was given a z-index of 400, which is too high and interfering as you can see, but it was needed to be that high to top the experimental-screen styling, which had a z-index of 399…
Without it, you get this effect:
Can you take a look at possible solutions?
Is it an option to lower the experimental element to 1, and the powered-by to 2?
Where are you seeing this @chapoi? On meta this is not happening.
Hmm, that was locally. What is your screenshot showing exactly?
Meta, I’ll have to take a look at a couple other situations
I tried this locally this morning and it does seem to address the issue you show here.
This should be fixed now – thanks.
https://github.com/discourse/discourse/pull/36692
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
