Horizon Theme
:information_source: Summary Horizon is a simple, beautiful theme that improves the out-of-the-box experience for Discourse sites.
:eyeglasses: Preview Try it out here on Meta or Theme Creator
:hammer_and_wrench: Repository Horizon is part of Discourse core.
:question: Install Guide There is no need to install Horizon, it is preinstalled as part of Discourse core.
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Features
Horizon offers a simple, user friendly design. We’ve focused on ensuring members can find the information they need and participate in meaningful conversations with fewer distractions.
Topic list with personalized welcome banner
Categories and Latest Topics layout
Latest topics list
Topic cards that provide just enough information
Easy reading with less visual noise
Custom color palettes for a unique look and feel
Light mode
Dark mode
Theme component / plugin compatibility
As a relatively new theme, and one that is quite opinionated in its styling, Horizon is not perfectly compatible with all theme components at this time. While we will work to ensure the most popular components are compatible with Horizon, we recommend that sites interested in customization use the Foundation theme instead.
Compatible
We have tested the following features with Horizon and confirmed they work. There may be opportunity for improvement; please let us know if you have ideas for how to improve compatibility. Anything not listed here is either only partially compatible, incompatible, or not yet tested.
Partial compatibility
Please let us know if compatibility with this feature is important to you; that will help us prioritize improvements to the theme component / plugin or Horizon.
Incompatible
  • Easy Footer
  • Custom Header Links
It took me a moment there to realize the new topic button had been moved away from the main area.
If the sidebar is hidden does that mean the only way to create a topic is via keyboard shortcut?
Hi, I want to disable fullwidth view, is this no longer possible?
I have two questions regarding the Horizon theme.
chrome_2025-04-14_01-11-27
First, I cannot find the paintbrush icon for Theme Settings. Could you tell me where it is located and how to make it show?
Second, the display appears to be incorrect when using Chinese.
You’d need to make sure all of the horizon palettes are user selectable in the color palette area of the admin panel.
It is not possible. We’ve integrated the full width styles into the theme. We have done this for various reasons but one of them is preparatory work to bring full width setting into core.
Okay, but that’s a lot of wide space on a big screen, will the setting in the core be in the theme settings ? Will i be able to turn off the fullwidth from the settings?
The one thing that seems to bother me a lot is on the main page where the category is in the bottom right corner and the username is underneath the topic title.
I find myself visually scanning every single time to the bottom right as for me, the category is much much more important than who replied last to the topic. And also I don’t seem to see any tags, those are also more important to me than who replied last. I guess unless I know a lot of people on a forum, I don’t seem to prioritize too much who replied last.
Does anyone else feel the same way?
The reply or like icon doesn’t work. I saw a theme where you clicked on the heart and it gave you the like. The reply button went to the last page.
twitter, facebook, reddit all work this way.
It also doesn’t display the name of the user who posted it. Having to guess who posted it from the photo is kind of weird.
Is there a reason that clicking the user-avatar and name doesn’t do anything? I’d expect it to open the user-card.
I’d also love to be able to switch to showing the full name, but de-selecting prioritize username in site settings doesn’t change the field:
I recently did a PR to show full name on topic cards. I’d find it quite helpful and consistent on both views and it seems a simple check?
https://github.com/discourse/discourse-topic-cards/pull/48
Hi, if i enable the sidebar in the dropdown menu, the new topic button is fixed in there is there a work around?
how to show the topics view count?
Yes, but in all topic cards / lists
Hmm… looking again, I don’t think this theme shows the views.
Thanks nolo! The PR is welcome in the theme itself. We ported the component to live inside of the theme as it is so closely related, we want to keep it all consolidated here.
@jordan.vidrine Can an option to change the color mode colors be placed into the theme settings?
Options such as:
var(–background-color)
var(–d-content-background)
This happens on both my instance and on meta.discourse.org.
When the chat window is opened, and the composer window is launched it pushes the chat box untop of the composer window as seen below:
Then when the composer is on the right side position, the chatbox is floating as shown below:
@jordan.vidrine @Discourse
Can the table of contents button be a circle instead of an oval? IMO it would seem more consistent :person_shrugging: .
some love is needed with the dropdown menu GitHub - paviliondev/discourse-dropdown-header: A theme component to add links in the header with dropdowns · GitHub
or is there a discourse-supported top menu component already compatible with Horizon?
Header Submenus, perhaps :thinking:?
