Repackaging a markdown-it extension as a Discourse plugin
markdown.it the CommonMark engine used by Discourse has a wide array of plugins
Header anchors, definition lists, smart-arrows and the list goes on and on.
First a warning
:warning: CommonMark is meant to be… Common. The further you move away from the spec the less Common your Markdown becomes. It can make it harder to port to other solutions and, if not careful, cause internal inconsistencies in parsing. Before repackaging anything be sure to answer the question “do I really want to repackage this?”
I just finished repackaging Discourse Footnote and have some lessons to share about how to do this right.
Steps for the lazy
If you are lazy and just want to get started the easiest way is just to fork footnotes and swap files and var names. I was pretty careful to make sure it follows best practices so you should have solid example.
Opening moves, a minimal repackage
From what I can tell the majority of markdown.it plugins are shipped as vanilla js files. In many cases plugins are simply shipped as a single js file, like this: markdown-it-mark.js.
Ideally you want to leave the original intact, that means you can simply copy an updated version of the file into your plugin without needing to mess with the existing plugin.
The first problem you will hit is that you have to teach your plugin to load this JavaScript on the server cause the Markdown engine runs on the server as well. To do though you can simply copy the file as is into assets/javascripts/vendor/original-plugin.js then in your plugin.rb file you would add:
# this teaches our markdown engine to load your vanilla js file
register_asset "javascripts/vendor/original-plugin.js", :vendored_pretty_text
Once you have the actual body of the plugin included you need to teach our pipeline how to load and initialize it:
Create a file called assets/javascripts/lib/discourse-markdown/your-extension.js
This file will be auto loaded cause it ends with .js AND in the discourse-markdown directory.
A simple example can be:
export function setup(helper) {
  // this allows you only to load your extension if a site setting is enabled
  helper.registerOptions((opts, siteSettings) => {
    opts.features["your-extension"] = !!siteSettings.enable_my_plugin;
  // whitelist any attributes that you need to support,
  // otherwise our sanitizer will strip them
  helper.whiteList(["div.amazingness"]);
  // you can also do fancy stuff like this
  helper.whiteList({
    custom(tag, name, value) {
      if ((tag === "a" || tag === "li") && name === "id") {
        return !!value.match(/^fn(ref)?\d+$/);
  // finally this is the magic that you would use to register the extension in
  // our pipeline. whateverGlobal is the name of global the plugin exposes
  // it takes in a single (md) var that is then used to amend the pipeline
  helper.registerPlugin(window.whateverGlobal);
Always be testing
Discourse’s bin/rake autospec is plugin aware :innocent:
This means that when you add the file spec/pretty_text_spec.rb every time you save it the plugin test file will run.
I use this extensively cause it makes work so much faster.
Say you added a plugin that changes every number in a post to 8 circle, you can call it discourse-magic-8-ball.
Here is how I would structure the tests:
require "rails_helper"
describe PrettyText do
  it "can be disabled" do
    SiteSetting.enable_magic_8_ball = false
    markdown = <<~MD
      1 thing
    MD
    html = <<~HTML
      <p>1 thing</p>
    HTML
    cooked = PrettyText.cook markdown.strip
    expect(cooked).to eq(html.strip)
  it "supports magic 8 ball" do
    markdown = <<~MD
      1 thing
    MD
    html = <<~HTML
      <p>8 circle thing</p>
    HTML
You may need to “decorate posts”
In some cases plugins work best when they add extra “dynamic” features to your posts. Examples of that are the poll plugin or the footnotes plugin that adds a “…” that dynamically shows a tooltip.
if you need to “decorate” posts add assets/javascripts/initializers/your-initializer.js
function magicUpTheElement($elem) {
  // your amazing magic goes here
export default {
  initialize(container) {
    if (!container.lookup("site-settings:main").enable_magic_8_ball) {
      return;
    withPluginApi("0.8.9", (api) => {
      api.decorateCooked(($elem) => {
        magicUpTheElement($elem);
You may need to “post process” the posts
In some cases you may need to “post process” posts, the markdown rendering engine, by-design is not aware of certain information like, for example post_id. In some cases you may want server side access to the post and “cooked” html, this can let you do things like trigger background jobs, synchronized custom fields or “correct” auto generated HTML.
For footnotes I needed a distinct id for each footnote, which meant I needed access to post_id, so I was forced to make changes to the HTML in the post processor (which runs in sidekiq)
To hook in you would add the following to your plugin.rb file:
DiscourseEvent.on(:before_post_process_cooked) do |doc, post|
  doc.css("a.always-bing").each do |a|
    # this should always go to bing
    a["href"] = "https://bing.com"
You may need some custom CSS
If you want to ship custom css, be sure to register the file in plugin.rb
Add your css to assets/stylesheets/magic.scss and then run
register_asset "stylesheets/magic.scss"
Remember that we “auto-reload” changes so you can amend your plugin CSS and see changes on the fly in development.
Good luck with your repackaging adventures :four_leaf_clover:
This document is version controlled - suggest changes on github.
I see some superset tools that extends Markdown, like Quarkdown seems to be very powerful.
Is there a way to replace markdown-it extension with tools like Quarkdown?
