This plugin is now bundled with Discourse core and is enabled by default. There is no need to install the plugin separately.
Enabling Footnote
The Footnote plugin is default enabled but can be disabled/enabled from the admin/plugins page:
Features
Once enabled, you can add footnotes to your posts by typing them in like this:
A sentence that needs a footnote. ^[The footnote]
Another sentence that needs a footnote. ^[The second footnote]
Or like this:
A sentence that needs a footnote. [^1]
Another sentence that needs a footnote. [^2]
[^1]: The footnote
[^2]: The second footnote
You can mix and match both styles within a post, as well as use non-numbered anchors.
There are two ways to display the footnotes, controlled by the display footnotes inline admin setting:
Non-inline:
Inline:
The inline versions are both Quote and mobile-friendly.
Settings
| Name |
Description |
| enable markdown footnotes |
enable footnote markdown on this site |
| display footnotes inline |
enable inline expansion of footnotes |
Hosted by us? This plugin is available on all of our hosting tiers Footnote | Discourse - Civilized Discussion
Development History
Discourse footnote re-packages the footnote markdown.it extension by @Vitaly as a Discourse plugin.
Check document
Perform check on document:
Kayla
58
Just a heads up that the extension does not seem to all allow for the regular markdown for footnotes using [^1]. I do not get formatted footnotes unless I use the “inline” formatting, like so:
Enabling footnotes using inline footnote formatting results in auto-numbered footnotes which then appear below the post together, while also-enabling inline expansion enables the ellipsis tooltip-like experience with no footnotes appearing below the post. If you have the inline expansion option enabled, your post preview window will look like traditional numbered footnotes, but you’ll see the inline expanded effect after publishing.
I appreciate the automatically-numbered footnotes using the inline formatting, it just took me a few tries to figure out how I should actually format the markdown and which options would get them to behave as desired. Hopefully this comment helps someone else avoid the same confusion.
Edit to add: The inline expansion option is how your footnotes will appear on mobile, regardless of whether that option is enabled (for desktop also).
Recipe for allowing your users to create inline popup content using this Discourse Footnote Plugin:
Combine this Plugin with the Composer Footnote Button Theme Component (it provides a button in the Composer/Editor to create footnotes)
You can put anything inside the popups, including HTML.
Examples:
Text
Text and Image Upload
HTML Content
jrgong
(jrgong)
66
Does the footnote plugin also work on public pages? In my specific case I want it NOT to work on public pages and only be visible in the regular topic view (to use it for internal notes etc)
@jrgong – no…
However, there is this alternative approach for which I’m in the process of developing a Theme Component… over on Github.
pfaffman
(Jay Pfaffman)
68
Looks like this got moved to core 17 hours ago.
I’ll let someone else update this appropriately.
Translation missing: en.The discourse-footnote plugin has been integrated into discourse core. Please remove the plugin from your app.yml and rebuild your container.
LoveMCJ
69
After moving to core,
I deleted the plugin from app.yml and ran ./launcher rebuild app,
but the settings remain on the plugin page. Is it okay to just leave it like this?
That’s the new one.
Here’s a shot of both for comparison:
LoveMCJ
71
That’s a really nice sound!
Thank you for sharing.
blake
(Blake Erickson)
72
Thanks for mentioning this, I just pushed a fix.
pfaffman
(Jay Pfaffman)
73
The other issue is that you don’t need to install the plugin anymore, and if you have installed it, you need not to include that git clone in your yml file.
I was too slow in updating the topic with the new info and you beat me to it.
I’ll add my bit now anyway…
Discourse Footnote has now been bundled with Discourse core, so this plugin will no longer need to be installed separately.
If you self-host you should see some information on your dashboard about removing it from your app.yml.
Hosted by us? This change will not affect you in any way.
You can continue to enjoy this plugin and not worry about a thing.
pfaffman
(Jay Pfaffman)
75
Yeah. Sorry about that.
That’s awesome! I knew you had a plan. I should have just waited, as the other thing I pointed out was, in fact, a problem that was, in fact, dealt with by someone else, and I should have just been patient since I knew you were going to hangle it. (And it’s so pretty, too!).
It’s still been less than 24 hours, so, you know, that’s pretty good too.
Thanks.
JammyDodger
(JammyDodger)
Split this topic
76
