Personalizzare Discobot per il tuo sito
:bookmark: This guide explains how to customize Discobot, the built-in assistant bot in Discourse, to better match your community’s persona and needs.
:person_raising_hand: Required user level: Administrator
Discobot is a special user in your Discourse community that helps new members learn about the platform. As an administrator, you can customize various aspects of Discobot to better fit your community’s style and requirements.
Modifying Discobot’s user profile
To customize Discobot’s profile:
  1. Go to Admin > Users and select the Discobot user.
  2. Select “Preferences” or click “Visit this user’s preferences page to edit their profile”:
Once in the Preferences section, you can modify the following settings:
Account settings
  • Name: Click the “Edit” button to change Discobot’s name.
  • Image: Click the “Edit” button to upload a new avatar image.
  • After making changes, click the “Save Changes” button.
Profile settings
Customize Discobot’s profile information as needed.
Email settings
Adjust email-related settings as needed.
Updating Discobot’s welcome message
To change the welcome message sent by Discobot:
  1. Go to Discobot’s profile (https://example.discourse.com/u/discobot/summary) and select “Messages”.
  2. Click on “Sent”.
  3. Find a greeting message that you want to modify.
  4. Copy a unique part of the message, such as “I’m only a robot”.
  5. Navigate to the Admin Interface (https://example.discourse.com/admin)
  6. Go to Appearance > Site Texts (https://example.discourse.com/admin/customize/site_texts)
  7. Paste the copied text into the search window. When the greeting message appears, click “Edit”.
  8. Update the greeting message and click “Save Changes”.
Limitations and additional information
  • You can reuse existing variables in messages (like %{title}), but you cannot add new ones.
  • Discobot must remain an administrator; this role cannot be removed.
For further customization needs or feature requests, consider posting in the Feature category.
38 Mi Piace
Is it possible to make a new conversation discobot with With members and make a new certificate for them ?
I am admin to an educational forum and I want to make a new conversation with a new certificate :slight_smile:
3 Mi Piace
No, you cannot currently customise the full experience.
3 Mi Piace
Is it possible to know the codes for messages such as %{title}
Excuse me for my many questions :slight_smile:
Questions are fine. :slight_smile:
You can reuse any existing variables in the message but you cannot add new ones.
5 Mi Piace
many thanks @HAWK
Is it possible to define the existing variables if possible? :slight_smile:
1 Mi Piace
I suggest adding that either
  1. People need to update the Discobot’s profile About me because it’ll still say message or mention @discobot even after you change its name
or
  1. Maybe Discourse could remove the username from the default message? I went ahead and edited our About me to just say
Hi, I’m not a real person. I’m a bot that can teach you about this site. To interact with me, send me a message or mention me anywhere.
Just in case we have to change it again, we don’t need to remember to also change the About me.
4 Mi Piace
Is this something that’s going to be possible in the future? The current question/answer format of fortune and quote is sufficient for what I have in mind.
1 Mi Piace
@codinghorror is extending the discobot functionality on our roadmap at all?
2 Mi Piace
That’s a good point we should make that copyedit, @tshenry can you take it? No need to deal with it retroactively just for new ones. Say “mention me by name” so editing the name doesn’t require editing the “about me”.
@hawk we don’t plan on extending discobot at the moment.
7 Mi Piace
Should be done with the following!
https://github.com/discourse/discourse/pull/11820
8 Mi Piace
Does Discobot have to be a Moderator or can I take this role away from him? I mean, will he still work then?
2 Mi Piace
As far as I can tell from looking at the code and the UI, Discobot should never be able to become a moderator.
If you meant an admin, then no, unfortunately there is no way to take the admin role away from DIscobot at this time.
7 Mi Piace
Grazie per la risposta. Negli ultimi post, è possibile personalizzare la formazione utente di discobot e la formazione utente avanzata o è ancora standard? Riceviamo molto traffico di ricerca con la parola “capybara”, ma potremmo voler provare un altro termine?
1 Mi Piace
In realtà credo che quello a cui mi riferisco potrebbe essere qui: Customizing Discobot for your site - #7
2 Mi Piace
C’è un modo per un amministratore di attivare o disattivare una particolare parte del tutorial?
Ad esempio, il tutorial sulla bandiera richiede all’utente di selezionare la bandiera “Inappropriata”. Questa bandiera è nascosta nella nostra istanza perché non si adatta al nostro caso d’uso. Di conseguenza, i nostri utenti non possono completare il tutorial. Se potessi semplicemente disabilitare/saltare questa singola sezione, potremmo riattivare il tutorial.
2 Mi Piace
Potresti cambiare le istruzioni del passaggio, in modo simile a come è possibile saltare il “mi piace” a un post quando i “mi piace” sono disabilitati. Disabilita i “mi piace” - aggiorna il tutorial di discobot
3 Mi Piace
Non è possibile rimuovere o aggiungere passaggi, ma è possibile personalizzare il contenuto del corpo dei passaggi esistenti (ma non i trigger).
4 Mi Piace
Mi piacerebbe occuparmene e addestrarlo a rispondere a domande relative all’argomento principale del forum utilizzando LM / chatgpt ecc… è possibile?
È meglio creare la propria IA persona/bot piuttosto che cercare di personalizzare discobot.
1 Mi Piace
