¿Enlace al primer mensaje no leído?
We have a Discourse instance (forum.ohlasy.info) and a separate website (ohlasy.info) that displays a list of latest topics pulled from /latest.json. Users can click on the topic name to get to the discussion. The question is, where does the link lead to? I have tried /t/:id and /t/:id/latest. The first link always leads to the beginning of the topic, the second one leads to the last post. Is there an option to go to the first unread post for the current user (if logged in) and to the beginning of the topic otherwise?
1 me gusta
Sorry, I misunderstood the question! There is no single magic link that’ll take you to two different locations in the topic.
There is, however:
  • a link that will take you to the :arrow_down: bottom of the topic consistently
    https://meta.discourse.org/t/slug/106476/last
  • a link that will take you to the :arrow_up: top of the topic consistently
    https://meta.discourse.org/t/slug/106476/1
2 Me gusta
Thank you! Neither of these options work well for us, though. Linking to the first post doesn’t make much sense for logged-in users who have probably read most of the topic already. And linking to the latest post doesn’t work well for… almost anybody. Those who have seen a part of the topic would lose track and those who didn’t would be thrown in the middle of a discussion, having to scroll to the top.
Would you consider adding / accepting a feature that would allow linking to the latest post read by the logged-in user or to the first post if the user is not logged in?
Or do you have other suggestions how to make this “latest posts on our discussion forum” website box work well?
I am open to adding an /unread postfix like we have for /last, feel free to send a PR
5 Me gusta
Note, there is a subtle difference between these two:
  • latest read post
  • first unread post
See also:
5 Me gusta
Did this ever get added Sam? Going to t/id/unread doesn’t work - but perhaps a different word is being used?
If it hasn’t been added this would be a really nice feature to have :blush:
Nope, not added yet.
I too would love a “go to first unread” keyboard shortcut. It is a nice power user feature that allows you to regain control if you are dumped into a topic you have already started tracking far into the topic.
Concrete example:
Ability to Jump to First Unread post in Topic Navigator / Progress Bar has not progressed over the years, same goes for: Remembered Topic location should be "First Unread" post instead of "Last Read" post
I think as it stands today, @codinghorror is happy to add a keyboard shortcut here for first unread. But we have not gotten to it yet, nor scheduled it.
I guess it is such an edge case to have these giant topics like @Wingtip tends to have AND have someone actively lobby for it.
The other problem with this power-user feature is that it is very hard to explain per: Will disable_jump_reply make a return? - #10 by codinghorror
5 Me gusta
I’m glad you would like to see it too Sam and I hope we’ll see it soon :blush:
Another place where I think it would be incredibly handy is when viewing a post via the flag system - it would be nice that it either ignores you own personal position, or, whenever you click through to a specific post for and Topic it asks you on leaving whether you would like to retain your original position, or set the most recent portion. If it tells you which post you had previously see (and maybe all you to jump to it) along with the post you later came in to (perhaps via review queue or post link) I think that would be super useful :+1:
The flag system is definitely a problem for me atm, as I am avoiding carrying out those duties as I don’t want to lose my own position in those topics. Pretty sure others probably feel similarly?
2 Me gusta
Solo me preguntaba si se hizo algún progreso en esto después.
Estoy considerando migrar algunos foros más a Discourse (junto con nuestro sistema de página de inicio personalizado), pero una de las mayores críticas que tuvimos en instalaciones anteriores es que esos enlaces (en nuestra página de inicio y páginas personalizadas) siempre iban a la primera publicación y la gente se frustraba al tener que desplazarse por el hilo nuevamente.
Creo que lo que es cierto hoy es que el enlace a un hilo irá a la última publicación leída si hay mensajes no leídos, o a la parte superior del hilo si no los hay, o si la cuenta no ha iniciado sesión. (Por favor, corríjame si me equivoco)
Si te refieres a enlaces dentro de Discourse, sí, pero nos referimos a enlaces que podemos usar fuera de Discourse (como en una página de inicio personalizada o un sitio principal).
Creo que esto es muy necesario. Pero tampoco debería ser solo un atajo de teclado porque uso el sitio en mi móvil mucho. ¿Un botón junto a los números de página?
3 Me gusta
¿Tienes alguna experiencia reciente que te haga sentir así? Siempre es útil recopilar esas anécdotas del mundo real.
3 Me gusta
Mi propia experiencia diaria.
Dirijo un foro muy activo y quiero leer todo, pero no siempre tengo tiempo.
Luego, cuando me @ mencionan o responden en una publicación, recibo una notificación. No puedo hacer clic en la notificación porque sé que saltará muy abajo en la lista y me perderé muchas publicaciones, es una pesadilla absoluta intentar desplazarse hacia arriba y encontrar dónde me quedé.
Por lo tanto, mi área de notificaciones nunca se usa, lo que significa que me pierdo las notificaciones hasta días después, y a veces son importantes.
Y si veo que tengo una @ mención en un hilo llamado “Hilo de ejemplo”, y ese hilo no es fácil de ver en la lista, ni siquiera puedo buscarlo porque eso me llevará hasta la parte superior del hilo y tendré que desplazarme hasta el final para encontrar dónde me quedé.
Simplemente no hay una manera fácil de abrir el hilo donde me quedé si tengo una notificación allí.
¡Es una situación realmente mala para mí!
4 Me gusta
Sí, esto es lo que se me ocurre también: algo como el botón “atrás” que tenemos actualmente en la línea de tiempo que aparece si te desplazas en la otra dirección, pero para ir al principio de tu primera publicación no leída en su lugar.
Me imagino que podría ser una preferencia del usuario si aparece o no.
Lo he querido en el pasado, pero personalmente no he sentido la necesidad de ello recientemente, así que las historias ayudan a entender de dónde viene la solicitud, gracias.
5 Me gusta
