user_field 정보가 잘못됨 - API 문서
create user field
I see
  "user_field[name]": "string",
  "user_field[description]": "string",
  "user_field[field_type": "string",
  "user_field[required]": true
Are you sure ?
I think it should be something like
  "user_field: {
     "name": "asdf",
     "description": "asdf",
     "field_type": "confirm",
     "required": true
I believe that @blake wrote that documentation so let’s see what he reckons here.
Yes, if you are using Content-Type: application/json you should send it in like
The example in the api docs is using Content-Type: multipart/form-data, but I’ll be sure to update it to the json example.
Thank you @blake
Note:
The problem is .. i see application/json in the example (so that’s why my partner spent all hours to figure it out how to use this call)
I also struggled for about 24 hours solid with this as the docs example suggests application/json formatted requests for creating a new user be boolean for user_field
I was being told I hadn’t finished all the required user fields … but in my case I have an existing required user_field I need to enter data into that field and it should be formatted like this:
  "name": "Full Name",
  "email": "email@address.com",
  "password": "348hqpwfaed",
  "username": "UserName",
  "user_fields": {
    "1": "Required User Field Data"
The above formatting worked for me.
Are the docs correct in this case for creating a new user?
Nope that was still the form-data format. I updated it to use json so that the example matches the format. Thank you for bringing this up!
https://github.com/discourse/discourse/pull/30133
