السماح بعدة مسودات 'موضوع جديد'
Following a meeting, I volunteered for two separate tasks, requiring two separate threads.
I open a browser tab and begin one of them. I open a second tab to begin the second, and the “New Topic” button is replaced with a “Open Draft” button. I am prevented from beginning my second thread until I post my first thread.
This seems counter-intuitive in that one, to my knowledge, there is no way to save and edit drafts in Discourse, and two, it requires me to use a separate app (a text editor) to accomplish my work.
14 إعجابًا
Your draft is saved automaticly.
You find your drafts in the User menu
Ways to work on more than one topic are mentioned here
إعجاب واحد (1)
Thank you, but your links to another Meta thread appear to suggest workarounds that aren’t much better than simply composing my thoughts entirely off Discourse in a third-party text editor.
Thank you also for directing me to a list of my saved drafts. I did not know those existed, I don’t know how they were created, and it seems now I have many drafts from over several months to delete individually (or is there a way to delete them all at once?). Additionally, this still doesn’t provide a solution to this bug I seem to have encountered, in that I can’t draft two threads at once.
I don’t think it’s a bug. Just how the system works today. But regardless, why can’t you just make the first topic and then make the second topic afterward? Do they have to be posted seconds apart for some reason?
I am working on both at the same time. I might similarly ask why would the system not permit this?
إعجابَين (2)
I have no idea. I was just noting that it didn’t seem like a bug. I wasn’t saying the current way is ideal.
Personally, I’ve almost never run into this issue before. Sure, it would be nice to be able to make multiple drafts at once. But I do wonder how common the use case is.
Create a PM to yourself is my recommendation.
5 إعجابات
I spent some time writing a theme component to add a ‘Save draft’ button to the composer - as well as a ‘View drafts’ button. I abandoned it in the end as the behaviour with new topics made it counter intuitive.
As a sample use case - I use this feature to save drafts on Twitter. It works in a similar way to Discourse - click Cancel and you are asked if you want to Delete or Save draft. The difference with Twitter is it does allow you to save more than one draft for a new topic. This is useful e.g. if drafting a few tweets late at night and saving them to post at a more appropriate time (or more often not after you’ve had time to sleep on it!)
The ‘Save draft as PM’ option is a good work around as Jeff recommends - providing you know how to convert a Topic into a PM and vice versa.
I would upvote this feature request of being able to save more than one draft of a + New Topic as I think it would be a useful addition - and more intuitive than using PMs to self to do this. It would also have the advantage of keeping all drafts in the same place.
7 إعجابات
أحد عملاء Discourse for Teams يسأل عن حقيقة أنه من الممكن وجود ردود مواضيع متعددة قيد التقدم في نفس الوقت ولكن يمكنك فقط إنشاء موضوع جديد واحد قيد التقدم في كل مرة. لقد وجدت نفسي غالبًا في موقف أكون فيه في منتصف كتابة موضوع جديد أطول وأرغب في الضغط على زر الإيقاف المؤقت حتى أتمكن من إضافة رد على شيء آخر.
تبدو الحلول الحالية هي القيام بأحد الإجراءات التالية:
  1. إلغاء ونسخ/لصق المنشور في محرر نصوص في مكان آخر
  2. إلغاء ونسخ/لصق المنشور في رسالة خاصة لنفسك
  3. الحفظ كـ مسودة مشتركة (إذا كنت موظفًا ويسعدك أن يرى الموظفون الآخرون مسودتك قبل نشرها)
    كل هذه الحلول غير عملية وغير ودية للمستخدم، خاصة في سياق Teams حيث قد يعمل المستخدمون على عدة مواضيع جديدة في وقت واحد وقد لا يكونون مرتاحين أو سعداء بالحلول البديلة. هل هناك سبب معين لعدم إمكانية ذلك حاليًا؟ هل يمكننا بناؤه؟
10 إعجابات
تاريخيًا، إنها ميزة للمستخدمين المتقدمين للغاية، ونحن ننتظر العملاء من المؤسسات لطلبها، أو حتى للوصول إلى قاعدة الثلاثة.
لدينا واجهة مستخدم مسودات أفضل بكثير (علامة تبويب المسودات موجودة الآن في ملف تعريف المستخدم الخاص بك، ولم تكن موجودة قبل عام أو أكثر)، لذا فإن الأساسيات موجودة الآن لإضافتها، إنها مجرد مسألة تحديد أولوياتها بالنسبة لجميع أعمالنا الأخرى.
12 إعجابًا
أجد نفسي غالبًا أبدأ ما قد يكون منشورًا أطول، بنية إنهاءه لاحقًا. ولكن بعد ذلك سأحتاج إلى بدء منشور آخر (أو في الواقع، آخر!؟). لذلك أُجبر إما على أ) نشر سلسلة غير مكتملة مع بعض الترويسة المعدلة [مسودة/غير مكتمل/لا تنظر إلى هذا بعد!!] :expressionless: أو نسخها إلى واجهة أخرى؟ أو مراسلة نفسي كما تقول.
كل هذه تبدو غير سليمة (وهي مجرد مشكلة للقيام بها في الواقع؛ مشكلة صغيرة، لكنها لا تزال مشكلة [في أي تطبيق ملاحظات قمت بوضعها فيه؟ لا أستخدم واحدًا باستمرار…])).
إن معالجة Slack للمسودات التي تمت إضافتها العام الماضي (؟) رائعة. لا داعي للقلق. انشر عندما تكون جاهزًا.
هنا أُخرج من الخطاب/Markdown لإعداد أي شيء أطول من بضع فقرات. (نحن نستخدم الخطاب لبعض التوثيق الداخلي على سبيل المثال. من الناحية المثالية، سيكون لدينا مجموعة من المنشورات التي ترتبط ببعضها البعض والتي يمكن مناقشتها، ولكن هذا كابوس حاليًا).
أود بشدة رؤية هذه الميزة مضافة :heart:.
12 إعجابًا
شكراً لك يا جوش! كما اقترح جيف سابقًا في هذا الموضوع، تتمثل إحدى الحلول البديلة في إنشاء رسالة خاصة لنفسك على الموقع نفسه ونسخ/لصق نص مسودتك فيها. ليست مثالية بالتأكيد ولكنها تعمل على جميع الأجهزة وتسمح لك بالوصول إلى مسودة واستئنافها من أي من أجهزتك.
إعجابَين (2)
بدافع الفضول، بدأت العب بميزة المسودات منذ أن يحاول منتدى الخاص بي إعادة التشغيل واستئناف عقود من المواضيع الشائعة. لذلك يبدو أن الوظيفة موجودة بالفعل للحصول على مسودات متعددة إذا كانت المسودات ردودًا على مواضيع موجودة مسبقًا.
العقبات هي هذه: الأولى هي إذا كنت ترغب في صياغة مواضيع جديدة متعددة. هناك حيث تسمح لك الواجهة فقط باستدعاء مسودة موضوعك الوحيد. يمكنني أن أفهم لماذا قد يشعر الناس بالإحباط حيال ذلك. بطرق معينة، يبدو هذا غير بديهي نظرًا لكيفية حصولك على مسودات ردود متعددة، وإن كان ذلك مسودة رد واحدة لكل موضوع، وهو ما يعد عيبًا آخر سأتطرق إليه لاحقًا. بما أنك تراجع وظيفة المسودات المتعددة هذه، اسمح لي بتقديم حل وبعض الاقتراحات.
هل يمكننا فقط الحصول على مسودات غير محدودة، على مستوى المنتدى وعلى مستوى الموضوع، على الإطلاق؟ من مستوى الموضوع، قد تستجيب لمسارات محادثة مختلفة. هذا هو أحد الحالات التي قد يكون لديك فيها مسودات متعددة قيد العمل. أنت تستجيب لمنشورات ذات مواضيع فرعية مختلفة أو مستخدمين مختلفين ضمن موضوع الموضوع هذا وترغب في تقسيمه إلى منشورات متعددة سهلة الفهم. قد لا يكون الرد في منشور واحد ضخم هو الحل الأفضل خاصة عندما يمكن أن يصبح بسرعة جدارًا نصيًا. أسباب وجود مسودات مواضيع متعددة واضحة بما فيه الكفاية: مواضيع مختلفة قيد الصياغة.
إليك حل مقترح: عندما تضغط على زر الموضوع الجديد أو الرد في طرق عرض المنتدى والموضوع، على التوالي، ربما تقدم هذه الخيارات الأربعة في مربع حوار:
  • استئناف المسودة
  • مسودة جديدة مع الاحتفاظ بالمسودات القديمة
  • مسودة جديدة مع استبدال المسودة الأخيرة
  • مسودة جديدة وحذف جميع المسودات
إذا كان هذا عددًا كبيرًا جدًا من الخيارات، فقد كان ذلك متعمدًا. لقد أخطأت في اختيار عدد كبير جدًا من الخيارات بدلاً من قليل جدًا. أعتقد أن التصميم يمنحكم المزيد من الاعتبارات نظرًا لتنوع سير العمل الذي قد يكون موجودًا. مرة أخرى، قد تكون على بعد 1000 خطوة مني ولديك بالفعل حل يتشكل داخليًا يحل كل هذا بشكل كافٍ. وإذا لم يكن الأمر كذلك، وإذا كنت تعتقد أن هذه حالة هامشية، فربما يمكن تمكين هذه الوظيفة إما عبر إعداد مسؤول أو مستخدم مستقبلي معطل عمدًا افتراضيًا و/أو يتم جلبه فقط عبر مكون إضافي؟
5 إعجابات
شكراً على الأفكار! لا أعتقد أنه من المنطقي وجود مسودات ردود متعددة لنفس الموضوع. في الواقع، نحن نثبط الناس عن الرد عدة مرات في موضوع للرد على أشخاص مختلفين. إذا كنت ترغب في فصلها، ابدأ موضوعًا مرتبطًا جديدًا.
لكنني أحب فكرة القدرة على الاحتفاظ بمسودات مواضيع جديدة متعددة دون المرور بصعوبات.
6 إعجابات
أدرك أن هذا سلوك غير مستحسن وأنك تحاول منع فوضى “الغرب المتوحش” التي تشوش هوية منتجك، ولكن إذا كنت ستذهب إلى حد وجود مسودات متعددة في واحدة، فلماذا لا تفعل الشيء الآخر أيضًا، ولماذا لا تذهب إلى منتصف الطريق وتذهب بالكامل؟ وربما كحل وسط، قم بإزالة المسودات المتعددة في سلسلة بشكل افتراضي لإرضاء مشاعر فريقك أو ثقافته التي تنظر إليها بازدراء، مع الاستمرار في منحنا الخيار حتى نتمكن من تشغيله.
لإضافة 2 سنتي. إنه أمر مزعج أن تضطر إلى إنشاء رسالة خاصة مع نفسك. وفي منتدى أنشط فيه، أقوم بإنشاء استطلاع أسبوعي ولا يمكنني نسخه ولصقه إذا لم أعد أتمكن من تعديل المنشور. لذلك، إذا حصلت على 4+ أفكار لاستطلاعات مستقبلية، فلن أتمكن من نسخها ولصقها جميعًا.
7 إعجابات
خيار “حفظ المسودة لاحقًا” الذي يظهر عند “إلغاء” موضوع من المحرر مفيد جدًا. أنا شخصياً أحب استخدام المسودات كمكان لتخزين الأفكار التي قد أنتهي منها أو لا أنتهي منها أبدًا.
لكنني أجد جانبًا واحدًا من السلوك مربكًا بعض الشيء: إذا اخترت “حفظ المسودة لاحقًا”، أعود إلى الصفحة الرئيسية، لكن الزر لا يزال يقول “فتح المسودة”. يبدو أن الطريقة الصحيحة لإنشاء موضوع جديد (أي غير متصل بالمسودة) هي تحديد وحذف المحتوى في المحرر - كل النص وجميع القوائم المنسدلة.
هل هذا صحيح؟ يبدو الأمر غير بديهي بالنسبة لي؛ إذا قمت للتو بـ “الحفظ كمسودة”، أتوقع أن يعود الزر في الصفحة الرئيسية إلى “موضوع جديد”، وأن يكون المحرر فارغًا إذا قمت بالنقر عليه.
4 إعجابات
هذه قيود أساسية في التصميم الحالي وستتطلب أسابيع من الهندسة لتعديلها. ليست ضمن قائمة أولوياتنا حاليًا.
يصبح الأمر أكثر تعقيدًا بسبب كيفية البدء في التفكير في مسودات متعددة للمنشورات حول موضوع واحد، فإن العبء المعرفي كبير جدًا.
أعتقد أن كل هذا ينبع من التوقع بأن الموضوع يمكن أن يحتوي على N مسودات. نظرًا للقيود الأساسية حيث يمكن للمواضيع أن تحتوي على مسودة واحدة فقط، فهذه هي الطريقة الوحيدة لحلها. إذا سمحنا لك ببدء موضوع جديد ثانٍ، فسيؤدي ذلك إلى تجاوز المسودة الحالية، كما هو مطبق حاليًا.
7 إعجابات
أنا سعيد جدًا بـ Discourse وقد ذكرت هذا بدافع المساعدة فقط
أرى. نعم، بالتفكير مرة أخرى، يمكنني أن أرى كيف سيكون تنفيذ مسودات متعددة صعبًا للغاية.
إعجابَين (2)
لقد لاحظت عدم اتساق في النسخة هنا مرة أخرى - إشعار “المسودة قيد التقدم” هو نفسه سواء كانت المسودة التي لديك قيد التنفيذ ردًا على موضوع أو موضوعًا جديدًا تعمل عليه. هذا يربكني دائمًا عندما أبدأ موضوعًا وأنسى أن لدي بالفعل مسودة موضوع قيد العمل. أول ما أفكر فيه هو “هذا الموضوع؟ أي موضوع؟”
ربما يكون الحل الأبسط هنا هو تغيير النسخة ببساطة إلى..
لديك مسودة قيد التقدم. ماذا تريد أن تفعل بها؟
بهذه الطريقة، لا يلزم وجود وظائف جديدة أو نسخ إضافية للتعامل مع كلتا الحالتين.
إعجابَين (2)
