2.9.0.beta7: Beveiligingsfix, bugfixes en meer
The 2.9.0.beta7 release includes a security fix related to an upstream dependency, detailed in the advisory GHSA-5v84-cg7p-ghvx. It introduces several new features, such as allowing the allow attribute in iframes, using full post width for Vimeo embeds, and adding Matariki holidays for New Zealand in the discourse-calendar plugin. Additional features include chat channel preview cards, a chat sidebar in the core sidebar, and the ability to publish user statuses to everyone. Bug fixes span multiple plugins, including corrections for ad rendering, subscription updates, reaction hints, and chat-related issues like drawer behavior and message loading. UX improvements include sticky query result headers, smoother sidebar transitions, and fixes for mobile usability and select-kit regressions. Other updates cover theme customization, language support (e.g., Thai), and various performance and compatibility fixes, including handling of unsupported browsers and improved splash screen behavior. david and david highlight the breadth of changes, noting that a full list is available in the detailed changelog.
Security Updates
This beta includes 1 security fix following an advisory on an upstream dependency. For more information, check the security advisory at Possible RCE escalation bug with Serialized Columns in Active Record · Advisory · discourse/discourse · GitHub
New Features
This release includes a number of additional smaller features, including:
  • Allow iframe allow attribute in posts
  • Use full post width for Vimeo embeds
Even more!
But wait, there’s more! We do our best to highlight new features and changes for you, but there’s always too many changes to detail. For a full list of new features, bug fixes, UX improvements, and more, be sure to review the Additional Features and Fixes listed below.
Plugin improvements
discourse-data-explorer
UX Changes
  • Making the headers of the query results table sticky
discourse-theme-creator
Bug Fixes
  • Correctly defer loading of admin locale
discourse-adplugin
New Features
  • Support placing ads between topic list for house ads
Bug Fixes
  • Don’t render the connector when we shouldn’t display an ad in the topic list item.
discourse-assign
UX Changes
  • Don’t display assign user menu glyph when sidebar is enabled
discourse-calendar
New Features
  • Add Matariki holidays for nz
Bug Fixes
  • Generate definitions for indonesian holidays
  • Delete event posts not automatic holidays
discourse-saved-searches
Bug Fixes
  • Don’t create posts for trashed topics
discourse-subscriptions
Bug Fixes
  • Allow user to update card details for recurring subscriptions
discourse-reactions
UX Changes
  • Hints the reason you can’t remove a like/reaction
discourse-checklist
Bug Fixes
  • Make other checkboxes read-only while updating the one.
discourse-translator
Bug Fixes
  • :globe_with_meridians: Add lang mapping for Thai
discourse-chat
New Features
  • Chat channel preview card
  • Chat-sidebar in core sidebar
Bug Fixes
  • Correctly opens channel from user card
  • Makes drawer not expanded on full page
  • Move CSS to sidebar-extensions
  • Marks drawer as not expanded when full screen
  • Selector modal was not correctly filtering channels
  • After create channel respects current mode
  • Do not fetch messages for draft channel with no ID
  • Create channel modal error with type param required
  • Prevents loading more to reset list
  • Correctly handles chat-channel-row active state
  • Use as_json instead of to_json for chat DM message bus
  • Allow user to direct message themself again and fix DM inconsistencies
  • Ensures no members found is displayed when filtering
  • Prevents destroyed emojis to break the UI
  • Tracking state is an ember object and should use set
  • Correctly make browse page scrollable
  • Shows only one sidebar on mobile
  • Notification shape
  • Various fixes to chat pages height/scroll
  • Prevents nil name/desc to nullify the other
UX Changes
  • Is focused background was not visible in dm creator
  • Fix width of full page chat when paired with experimental sidebar
  • Remove gap on sidebar with full page chat
  • Hides useless notices for chat
  • Fix channel msg indicator
  • Improve category hints when creating a channel.
  • Displays delete btn using red icon
  • Hide desc when empty and not editable
  • Do not focus composer on ipad
  • Moves join/leave button to about tab
  • Supports emoji in title of about view
  • Prevents ipad to autofocus filter input
New Features
  • Publish everyone’s status to everyone
  • Plugin outlet for sidebar
  • Auto remove user status after predefined period
Bug Fixes
  • Mobile usability issues in crawler view
  • Fixes few regressions in select-kit
  • Detect firefox `< 89 as an unsupported browser
  • Set resolver options on the legacy resolver
  • Update flaky bulk invite spec
  • Just inline the QUnit CSS in theme-test html
  • Ensure category-tag filter routes are functioning
  • Apply all watched words rules to user fields
  • Ensure splash screen <noscript> is loaded for legacy browsers
  • Ensure splash screen logic is iOS12 compatible
  • Add ember redirect for tags/:tag_id ->` tag/:tag_id
  • Min/max username length limits weren’t validated
  • Inputs using focusout regressed in #17345
  • Allow connector template names to be camelCase
  • Should be UploadReference instead of UploadReferences
  • Ensure there is no limit on tag list settings
  • Ensure pull-hotlinked can rewrite lone oneboxes
  • Correct error in ip-lookup component definition
  • Posts can belong to hard-deleted topics
  • Replace onebox markdown when pulling hotlinked image
  • Logout could fail due to cached user
  • Correctly display /admin/emails errors
  • Experimental sidebar preferences link not shown for users
  • Move ember-cli-deprecation-workflow to runtime deps
  • Incorrect currentUser could be cached for requests with API key
  • Vimeo regex pattern
UX Changes
  • Fixes navigation 1px jitter
  • Add classes to create-account modal for easier customization
  • Fix exp sidebar toggle alignment, add hovers
  • Skip length check on reply drafts
  • Less janky animation for experimental sidebar
  • Add border-box to stop padding from overflow
  • Makes splash dots use theme colors
  • A save should always have a cancel action
  • Don’t animate experimental sidebar on reload
  • Improve experimental sidebar transitions
  • Switch highlight/select colours in select-kit
  • Prevent experimental sidebar scroll jumps
  • Splash should always stick to top left corner of the viewport
  • Staff notice should utilize full post width
  • Prevent overlap between splash loader and splash text on some browsers take 2
  • Hide user menu bookmark link when experimental sidebar is enabled
  • Update categories/tags in sidebar only after saving.
  • Enforce bullet category style in sidebar
  • Mobile experimental sidebar improvement
  • Remove hardcoded colour value
  • Missing specificity
  • Retain category badge style on categories select kit.
  • Makes splash screen setting enabled by default
  • Use discourse-ready as a baseline for removing the splash
  • Made “Dismiss New” button clickable by replacing float method.
  • Hide sidebar li overflow, remove title margin
  • Improve experimental sidebar scrollbar
  • Minor experimental sidebar alignment changes
  • Remove experimental sidebar notification text
