Convertendo modais de controladores legados para a nova API do componente DModal
:information_source: If you’re implementing a new Modal, check out the main docs here. This topic describes how to migrate an existing controller-based Modal to the new Component-based API.
In the past, Discourse used an Ember-Controller-based API for rendering modals. To invoke the modal, you would pass a string with the name of the controller to showModal(). Under the covers, this made use of Ember’s Route#renderTemplate API, which is deprecated in Ember 3.x and will be removed in Ember 4.x.
To allow Discourse to upgrade to Ember 4.x and beyond, we’ve introduced a new component-based API for modals. This new API embraces Ember’s ‘declarative’ design patterns, and aims to provide clean DDAU (data down actions up) semantics.
Step 1: Move Files
Move the controller JS file and the template file to the /components/modal directory. This makes them a ‘colocated component’ which can be imported just like any other JS module.
Step 2: Update the JS file
Then, update the component JS definition to extend from @ember/component instead of @ember/controller [1]. Remove the ModalFunctionality mixin and update any uses of its functions according to the table below:
Before After
flash() and clearFlash() Create a flash property in your component and pass it to the @flash argument of <DModal>. By default the alert will be styled with the alert class which is a copy of the ‘error’ class, but it can be overridden using the @flashType argument.
showModal() Import the showModal function from discourse/lib/show-modal
closeModal action Invoke the closeModal argument which is automatically passed into your component
Old-style Modal Controllers would live ‘forever’, which meant we had to manually cleanup state. With the new Component-based API, the component will be created and destroyed when the modal is shown/hidden. In many cases that means your old lifecycle hooks are no longer required.
If you still need some lifecycle-based logic, use this table:
Before After
onShow() Use standard Ember component lifecycle (init() or Ember modifier)
afterRender Use standard Ember component lifecycle (init() or Ember modifier)
beforeClose() create a wrapper around the @closeModal argument which is passed into your component. Pass a reference to your close wrapper into DModal like <DModal @closeModal={{this.myCloseModalWrapper}}>
onClose() Use standard Ember component lifecycle (willDestroy() or Ember modifier)
Step 3: Update the Template
Replace the <DModalBody> wrapper with <DModal>. Add some new attributes:
  • Pass through the new @closeModal argument
  • Add an explicit class. To match the old behavior, take your controller filename and add -modal.
For example, if your modal controller was called close-topic.js, the new <DModal> invocation would look something like this:
<DModal @closeModal={{@closeModal}} class="close-topic-modal">
If the DModalBody invocation includes any other arguments, update them based on the table below:
Before After
@title="title_key" @title={{i18n "title_key"}}
@rawTitle="translated title" @title="translated title"
@subtitle="subtitle_key" @subtitle={{i18n "subtitle_key"}}
@rawSubtitle="translated subtitle" @subtitle="translated subtitle"
@class @bodyClass
@modalClass Use angle-bracket syntax with regular html attribute: <DModal class="blah">
@titleAriaElementId Use angle-bracket syntax with regular html attribute: <DModal aria-labelledby="blah">
@dismissable, @submitOnEnter, @headerClass Unchanged
If there was any footer content rendered after the old <DModalBody> component, use the new <:footer> named block to introduce it inside <DModal>. When using any named blocks, the body content should be wrapped in <:body></:body>. For example:
<DModal @closeModal={{@closeModal}}>
  <:body>
    Hello world, this is the content of the modal
  </:body>
  <:footer>
    This is the footer content. A `.modal-footer` wrapper will be added
    automatically
  </:footer>
</DModal>
Step 4: Update the showModal call sites
Previously, modals would be rendered using the showModal API, which would take a string (the controller name) and a number of opts. It would return an instance of the controller which could be manipulated:
import showModal from "discourse/lib/show-modal";
export default class extends Component {
  showMyModal() {
    const controller = showModal("my-modal", {
      title: "My Modal Title",
      modalClass: "my-modal-class",
      model: { topic: this.topic },
    controller.set("updateTopic", this.updateTopic);
To render new component-based Modals you should inject the ‘modal’ service (or access it using something like getOwner(this).lookup("service:modal")) and call the show() function.
show() takes a reference to the new Component class as the first argument. The only opt still supported is ‘model’, which can be used to pass all data/actions required for your Modal.
No reference to the component instance will be returned. Instead, show() returns a promise which will resolve when the modal is closed. The promise will resolve with any data which was passed to @closeModal.
import MyModal from "discourse/components/my-modal";
import { service } from "@ember/service";
  @service modal;
  showMyModal() {
    this.modal.show(MyModal, {
      model: { topic: this.topic, updateTopic: this.updateTopic },
Alternatively, migrate to the declarative API described in the main DModal documentation.
The functionality of the old options can be replicated as follows:
Old showModal opt Solution
admin n/a for component - remove it
templateName n/a for components - remove it
title move to <DModal @title={{i18n "blah"}}>
titleTranslated move to <DModal @title="blah">. This could be computed based on data from model if needed
modalClass move to <DModal class="blah">
titleAriaElementId move to <DModal aria-labelledby="blah">
panels Use the <:headerBelowTitle> named block to implement tabs in your component (example)
model unchanged
Step 5: Tests
Any tests should largely remain the same. The most common issue are:
  • Modals no longer have a default class based on their name. Classes must be specified explicitly in the template (see beginning of Step 3)
  • The d-modal wrapper no longer persists in the DOM when the modal is closed. To check all modals are closed, use a check like assert.dom('.d-modal').doesNotExist()
Profit!
Your modal should now work as it did before. To take further advantage of the new API, you may want to consider replacing showModal calls with a declarative strategy, and converting your Modal to be a Glimmer component.
Examples
Here are some example commits which demonstrate converting some of Discourse core’s modals to the new API:
This document is version controlled - suggest changes on github.
  1. Classic Ember Components are recommended in this guide because they provided the easiest migration path from Ember Controllers. But for simple modals, or if you’re happy to spend some time refactoring, modern Glimmer components are the better choice. ↩︎
20 curtidas
Isso parece ótimo. Me dá esperança de que eu possa converter meus modais para o Ember 4. Eu mal entendo o código Ember que escrevo, então escrever documentação que eu possa entender não é fácil. Muito obrigado por isso.
8 curtidas
Obrigado pelo tutorial! Olhar os exemplos foi muito útil. Consegui consertar meu modal de plugin personalizado que estava quebrado em uma hora.
4 curtidas
Estou trabalhando nesta conversão agora mesmo, mas estou encontrando um problema:
Anteriormente, nosso modal não tinha um controlador/definição JS correspondente, e conseguimos mostrar o modal através de showModal($HBS_FILE_NAME). Como o novo show() requer um componente para ser passado, preciso introduzir esta definição JS (esta é uma suposição correta?).
Adicionei algo como:
import Component from '@glimmer/component';
export default class SomeModal extends Component {
  constructor() {
    super(...arguments);
    console.log('Modal constructor')
e tenho o arquivo .hbs anterior (com as alterações necessárias para DModal) ambos no diretório /components/modal com o mesmo nome de arquivo. Ao tentar renderizar o modal (via getOwner(this).lookup("service:modal").show(SomeModal)), vejo meu log do construtor impresso no console, mas o modal não é renderizado.
É necessária alguma outra configuração no controlador/definição JS para esta alteração? Qualquer orientação seria muito apreciada!
Você não precisa disso se não estiver adicionando nenhum código.
Você pode ter apenas o arquivo .hbs.
O discourse-templates, por exemplo, não tem um arquivo JS correspondente para o template handlebars do modal.
Você adaptou seu template handlebars seguindo as instruções?
Existem erros no console?
2 curtidas
Obrigado pelo feedback! Grande :facepalm: da minha parte, eu havia movido os arquivos para o diretório .../discourse/templates/components/modal, em vez de .../discourse/components/modal. As coisas estão funcionando como esperado agora (com ou sem o controlador .js), obrigado!
3 curtidas
Você poderia me mostrar como chamar showModal() de um script dentro de um head_tag.html, por favor? No meu caso, preciso usar
document.querySelector(".actions .double-button .toggle-like");
para capturar o evento de clique, verificar a condição e, em seguida, mostrar um modal personalizado.
1 curtida
Agradeço muito o esforço que você fez para documentar isso tão claramente, David!
Consegui eliminar quase todas as depreciações para a 3.2 em uma tarde em nosso maior plugin.
3 curtidas
Como acessar um modal existente no core para modificá-lo agora?
No passado, eu usava isto (que não funciona mais):
api.modifyClass("controller:poll-ui-builder", {
Neste caso específico, o nome dessa classe parece estar bem declarado e inalterado.
2 curtidas
Dependendo do que você precisa modificar, acho que a melhor solução seria usar um PluginOutlet para injetar seu código personalizado, ou um PluginOutlet Wrapper para substituir/mostrar condicionalmente a implementação principal. (Você pode enviar um PR para adicionar um outlet se ele não estiver disponível)
Se você realmente quiser usar modifyClass, ainda será possível, é apenas que o modal agora é um componente e está aninhado em components/modal, então você o acessaria assim:
api.modifyClass("component:modal/poll-ui-builder", {
   pluginId: "your-custom-plugin-id",
   // insira código personalizado
4 curtidas
