hCaptcha для Discourse
:discourse: Summary Discourse hCaptcha supports hCaptcha integration into the local sign-up form.
:open_book: Install Guide This plugin is bundled with Discourse core. There is no need to install the plugin separately.
:discourse: Hosted by us? This plugin is available on all of our hosting tiers hCaptcha | Discourse - Civilized Discussion
Features
This plugin is designed to integrate hCaptcha into the sign-up form of Discourse forums. This plugin aims to enhance security and bot protection by leveraging the privacy-centric features of hCaptcha. The setup process is straightforward and consists of a few easy steps.
Configuration
:spiral_notepad: Ensure the enable local logins setting is active. Otherwise, the plugin won’t work.
  1. Create a hCaptcha account: Visit https://www.hcaptcha.com and choose the plan that aligns best with your requirements/traffic. For reference, hCaptcha offers a free plan that includes one million requests per month. A Sitekey and an Account Secret will be generated during the account setup process.
:rotating_light: Please keep your private keys safe and secure at all times.
  1. Go to Admin → Plugins → Installed → hCaptcha Settings
  2. Copy the Sitekey value to the hcaptcha site key setting and the Account Secret to the hcaptcha secret key setting.
  3. Enable the plugin via the discourse hcaptcha enabled setting.
17 лайков
Please help
1 лайк
It seems that you’re using a plugin, theme, or theme component that is interfering with the hCaptcha plugin. Try using safe mode by disabling the themes to start, and see if the plugin works then.
5 лайков
thank you for your response. we solved it with csp policy fix. but it was not opt for our site so we had to remove it and place in other security checks.
2 лайка
We have made a fix for this, if you want to give it a try it should work with out any issues now
2 лайка
6 posts were split to a new topic: Signin doesn’t work when hCaptcha enabled and keys not configured
:partying_face: This plugin is now bundled with Discourse core as part of Bundling more popular plugins with Discourse core. If you are self-hosting and use the plugin, you need to remove it from your app.yml before your next upgrade.
2 лайка
Just in case the dev team needs someday a docker compatible alternative to hcaptcha; , this one is nice too GitHub - altcha-org/altcha: GDPR, WCAG 2.2 AA, and EAA compliant, self-hosted CAPTCHA alternative with PoW mechanism. ; Free, open-source Captcha alternative | ALTCHA
