3.1.0.beta5 post update issues (inbox not working + sidebar strings not translated)
I updated to version 3.1.0.beta5 (7db6d27292). but when I click on the inbox link “error” something went wrong. gives an error. Also, some translations still appear in English. For example, translations like “My Posts” , “Toics”. I don’t see any errors in the error logs.
Hi mekici :slight_smile:
I don’t have answers to your inbox issue…
edit: Maybe, for some reason, the inbox URL is wrong? What URL does your inbox URL lead to?
However, for this one:
I suppose “Toics” is a typo and you meant “Topics”? For “My Posts”, we’re aware of the issue. It doesn’t get translated though the two “My Posts” strings are properly translated in admin → customize → text.
Here’s a screenshot from a French instance:
However, I don’t see where is the untranslated “Topics” text. Can you tell us where on the interface did you see it?
I think this sounds like this Contribute > Bug report Message category selector for group messages leads to "Error Something went wrong."
Hello. I did not make any changes to the URL. The group messages I’m talking about… /u/admin/messages/group/admins
yes, i have the same problem with this issue.
I see. “Everything” has been replaced with “Topics” very recently (today or yesterday), and it doesn’t take the translation into account the same way as “My Posts”.
I just upgraded my test instance and can repro the “Topics” translation issue:
Is the “admin” part from your URL an actual username? This is a default reserved username and thus an invalid URL.
If your username on your forum is mekici, it should link to /u/mekici/messages/group/admins.
I just want to ensure you didn’t alter the URL in a way that would cause confusion, but since we hard reports of a similar bug, this is probably legit.
There are two distinct issues in the topic though. 1) translations not loading 2) inbox not working.
yes admin is a real username.
Yes on the subject 1) translations not loading 2) inbox not working. has problems.
one of the problem is the same as in this thread.
Thanks for the reports mekici and confirming the “/admin/” part :+1:
We’re investigating both issues (inbox and translations) :slight_smile:
I think this will be fixed following:
https://github.com/discourse/discourse/pull/22179
To be merged soon.
