¿Problema de i18n en Inbox?
Some localization and its tips seems not working at /u/username/messages even change back to English.
When i click then go to /u/username/messages/group/some-characters-in-my-language and got below
My installed Discourse is v2.3.0.beta11 +34, but this problem also happen on the other previous beta version.
Error log
message
ActionController::UrlGenerationError (No route matches {:action=>"private_messages_group_archive", :controller=>"list", :format=>"json", :group_name=>"管理面板", :page=>1, :topic_ids=>nil, :username=>"ak"}, possible unmatched constraints: [:group_name])
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/journey/formatter.rb:57:in `generate'
Backtrace
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/routing/route_set.rb:744:in `generate'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/routing/route_set.rb:775:in `generate'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/routing/route_set.rb:822:in `url_for'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/routing/route_set.rb:273:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/routing/route_set.rb:331:in `block (2 levels) in define_url_helper'
/var/www/discourse/app/controllers/list_controller.rb:417:in `public_send'
/var/www/discourse/app/controllers/list_controller.rb:417:in `construct_url_with'
/var/www/discourse/app/controllers/list_controller.rb:179:in `block in generate_message_route'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/abstract_controller/base.rb:194:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/callbacks.rb:132:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/abstract_controller/callbacks.rb:41:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal/rescue.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/notifications.rb:168:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/notifications.rb:168:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/abstract_controller/base.rb:134:in `process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionview-5.2.3/lib/action_view/rendering.rb:32:in `process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.0.2/lib/mini_profiler/profiling_methods.rb:104:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal.rb:191:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal.rb:252:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/journey/router.rb:35:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/journey/router.rb:35:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/routing/route_set.rb:840:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-protection-2.0.5/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:32:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/tempfile_reaper.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/conditional_get.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/session/abstract/id.rb:232:in `context'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/session/abstract/id.rb:226:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/callbacks.rb:98:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/logster-2.3.0/lib/logster/middleware/reporter.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:18:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/executor.rb:14:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.0.2/lib/mini_profiler/profiler.rb:281:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/message_bus-2.2.0/lib/message_bus/rack/middleware.rb:57:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:163:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/engine.rb:524:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:605:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:700:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:548:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:144:in `start'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `<main>'
