Errore aggiornamento 3.3.0.beta2-dev
Ciao,
Abbiamo un problema di compatibilità del modulo “node” del motore durante l’aggiornamento.
error ember-template-lint@6.0.0: Il motore “node” è incompatibile con questo modulo. Versione prevista “^18.18.0 || ^20.9.0 || >=21.1.0”. Ottenuta “18.17.1”
Ora, quando si visualizza la dashboard, viene visualizzato “Sono disponibili aggiornamenti. Aggiorna!”. Tuttavia, quando controlla tutti gli aggiornamenti, non ne vengono visualizzati?
Stopping job queue to reclaim memory, master pid is 57284
$ cd /var/www/discourse & git fetch --tags --prune-tags --prune --force
$ cd /var/www/discourse & git reset --hard HEAD@{upstream}
Updating files:  16% (51/314)
Updating files:  17% (54/314)
Updating files:  18% (57/314)
Updating files:  19% (60/314)
Updating files:  20% (63/314)
Updating files:  21% (66/314)
Updating files:  22% (70/314)
Updating files:  23% (73/314)
Updating files:  24% (76/314)
Updating files:  25% (79/314)
Updating files:  26% (82/314)
Updating files:  27% (85/314)
Updating files:  28% (88/314)
Updating files:  29% (92/314)
Updating files:  30% (95/314)
Updating files:  31% (98/314)
Updating files:  32% (101/314)
Updating files:  33% (104/314)
Updating files:  34% (107/314)
Updating files:  35% (110/314)
Updating files:  36% (114/314)
Updating files:  37% (117/314)
Updating files:  38% (120/314)
Updating files:  39% (123/314)
Updating files:  40% (126/314)
Updating files:  41% (129/314)
Updating files:  42% (132/314)
Updating files:  43% (136/314)
Updating files:  44% (139/314)
Updating files:  45% (142/314)
Updating files:  46% (145/314)
Updating files:  47% (148/314)
Updating files:  48% (151/314)
Updating files:  49% (154/314)
Updating files:  50% (157/314)
Updating files:  51% (161/314)
Updating files:  52% (164/314)
Updating files:  53% (167/314)
Updating files:  54% (170/314)
Updating files:  55% (173/314)
Updating files:  56% (176/314)
Updating files:  57% (179/314)
Updating files:  58% (183/314)
Updating files:  59% (186/314)
Updating files:  60% (189/314)
Updating files:  61% (192/314)
Updating files:  62% (195/314)
Updating files:  63% (198/314)
Updating files:  64% (201/314)
Updating files:  65% (205/314)
Updating files:  66% (208/314)
Updating files:  67% (211/314)
Updating files:  68% (214/314)
Updating files:  69% (217/314)
Updating files:  70% (220/314)
Updating files:  71% (223/314)
Updating files:  72% (227/314)
Updating files:  73% (230/314)
Updating files:  74% (233/314)
Updating files:  75% (236/314)
Updating files:  76% (239/314)
Updating files:  77% (242/314)
Updating files:  78% (245/314)
Updating files:  79% (249/314)
Updating files:  80% (252/314)
Updating files:  81% (255/314)
Updating files:  82% (258/314)
Updating files:  83% (261/314)
Updating files:  84% (264/314)
Updating files:  85% (267/314)
Updating files:  86% (271/314)
Updating files:  87% (274/314)
Updating files:  88% (277/314)
Updating files:  89% (280/314)
Updating files:  90% (283/314)
Updating files:  91% (286/314)
Updating files:  92% (289/314)
Updating files:  93% (293/314)
Updating files:  94% (296/314)
Updating files:  95% (299/314)
Updating files:  96% (302/314)
Updating files:  97% (305/314)
Updating files:  98% (308/314)
Updating files:  99% (311/314)
Updating files: 100% (314/314)
Updating files: 100% (314/314), done.
HEAD is now at 33871c483 DEV: Add `disabled` attribute to form templates (#27033)
$ cd /var/www/discourse/plugins/discourse-ai & git fetch --tags --prune-tags --prune --force
$ cd /var/www/discourse/plugins/discourse-ai & git reset --hard HEAD@{upstream}
HEAD is now at d64cff7 DEV: use sinon for safer stubbing (#624)
$ cd /var/www/discourse/plugins/discourse-gamification & git fetch --tags --prune-tags --prune --force
$ cd /var/www/discourse/plugins/discourse-gamification & git reset --hard HEAD@{upstream}
HEAD is now at f163a9f Update translations (#135)
$ cd /var/www/discourse/plugins/discourse-reactions & git fetch --tags --prune-tags --prune --force
$ cd /var/www/discourse/plugins/discourse-reactions & git reset --hard HEAD@{upstream}
HEAD is now at 50d7698 DEV: Additional backfilling for like sync (#283)
$ bundle install --retry 3 --jobs 4
Fetching gem metadata from https://rubygems.org/.........
Fetching drb 2.2.1
Fetching csv 3.3.0
Fetching regexp_parser 2.9.1
Fetching mutex_m 0.2.0
Installing drb 2.2.1
Installing mutex_m 0.2.0
Installing csv 3.3.0
Fetching sass-embedded 1.77.1 (x86_64-linux-gnu)
Installing regexp_parser 2.9.1
Fetching nokogiri 1.16.5 (x86_64-linux)
Installing sass-embedded 1.77.1 (x86_64-linux-gnu)
Installing nokogiri 1.16.5 (x86_64-linux)
Bundle complete! 141 Gemfile dependencies, 173 gems now installed.
Gems in the groups 'development' and 'test' were not installed.
Bundled gems are installed into `./vendor/bundle`
1 installed gem you directly depend on is looking for funding.
  Run `bundle fund` for details
$ yarn install
yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
warning Resolution field "unset-value@2.0.1" is incompatible with requested version "unset-value@^1.0.0"
[3/5] Fetching packages...
error ember-template-lint@6.0.0: Il motore "node" è incompatibile con questo modulo. Versione prevista "^18.18.0 || ^20.9.0 || >=21.1.0". Ottenuta "18.17.1"
error Found incompatible module.
info Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command.
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:210:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:101:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/commands/runner/runner_command.rb:43:in `load'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.1/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.1/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.1/lib/thor.rb:527:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/command/base.rb:87:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/command.rb:48:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/commands.rb:18:in `<main>'
internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb:37:in `require'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/bootsnap-1.18.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
Spinning up 3 Unicorn worker(s) that were stopped initially
Sto riscontrando lo stesso errore.
Ciao,
È successo anche a me. La soluzione è farlo tramite la riga di comando.
cd /var/discourse
git pull
./launcher rebuild app
Spero che questo aiuti.
Ho avuto lo stesso problema. Sfortunatamente, mi ci è voluto un attimo per individuare l’errore e nel processo di aggiornamento sembra che abbia corrotto il mio database Postgres :expressionless:
Quindi è decisamente meglio seguire il suggerimento di ricostruire direttamente dalla CLI.
Modifica:
Sono riuscito a ripristinare un backup precedente dopo aver resettato il transaction log di postgres. Fortunatamente non era un sito di produzione, questo è stato spiacevole anche per un sito di test.
Amico mio, mi hai salvato la vita, GRAZIE!
Anche questa soluzione ha funzionato per me, grazie mille :100:
Per chiunque altro si trovi in questa situazione, non fatevi prendere dal panico, seguite semplicemente queste istruzioni.
Grazie per i report! Una ricompilazione dalla riga di comando è effettivamente la soluzione migliore.
Ho preparato questa correzione che mostrerà un messaggio alle persone prima che premano ‘aggiorna’ nell’interfaccia utente.
Modifica: ora unito
Sì, sembra che l’aggiornamento tramite la CLI l’abbia risolto anche per me. Mamma mia, mi aveva preoccupato. Sono contento di sapere che impedirà a degli idioti come me di incorrere di nuovo in questo problema tramite l’interfaccia utente.
