In two updated instances on tests-passed (one ‘clean’, with no other plugins or TCs), I’ve been unable to establish any actor.
- Go to
/admin/plugins/ap - Click on
+ Add Actor - Select
TagorCategory- if you select
Category, you can then select from the category picker that appears and all good - if you select
Tag, nothing happens, and you get this in the console (nothing in logs):
and this:
- if you select
Is this due to a change in core? It seems to work fine on Stable.
