I know I have a python tag already and it normally jumps in there when I start typing but it doesn’t now. It looks like it does when you create a new tag
But after I click the checkbox, the new tag shows up for just a nanosecond and then disappears, no tag:
There isn’t anything in the list of tags that can only be used in this category, although if I click in the field it again shows me just the wont-fix tag.
Just now I checked another category and found the following set of allowed tags. These are not a set of tags that anyone would have picked out for this category. I just deleted each one and clicked “Save Category” and when I come back in they are all back. The crazy thing is, it seems to let me delete one at a time, save and go back and it’s still gone, UNTIL I delete the last one, when I come back after that they have all returned.
I spot checked a few more categories and they all seem to have that weird set of tags. in fact I just checked Corner Bar again and it has them now too. If I hadn’t taken the screen shot at the top of this topic I would be questioning my sanity now.
If those tags match the top used tags in your community (you should be able to tell by looking at /tags or sort by count). Then that bug was fixed in the last couple of days and I’m sure one of the Discourse Team will be glad to upgrade you.
Then when I click into the first input box I see the following different set of tags. These ones match up with our top 5 tag in terms of usage, that wont-fix tag is not like the others.
I don’t expect to find any restricted tags in any of our categories.
You can restrict a tag to more than one category. For example, if you have two categories “Car Repair” and “Car Parts”, you could make it so a tag “transmission” can only be used in those two categories by adding them to the “Tags that can only be used” fields of both.
I looked through the first four sets and they all match your category settings. For example:
Oh you’re saying all those tag settings were not added by someone! Wow, this is all fallout from a commit labeled WIP that was putting top tags in category settings.
Should the tags be removed from all those categories’ settings? I can do that for you.
