Affiliate 링크 기능 - 재작성
Hello all,
Thinking of getting a forum, possible ways to monetise with display ads. Also looking at affiliate.
If any user posts a link are we able to inject the affiliate link - destination remains the same, just that we add our own tracking link.
thanks
3개의 좋아요
A quick search turns up some plugins that you may find useful:
If you’re unfamiliar with how to install plugins, this guide can help: Install plugins on a self-hosted site
good luck!
3개의 좋아요
If you’re talking about for something other than Amazon, I have a theme component that does it in what I thought to be a strange way. It would need to be changed to work for anything other than the home page for the site.
You’re welcome to fork it, or, if you have a budget, contact me and I’ll consider either modifying the above component or making an other one for you (depending on which makes more sense).
3개의 좋아요
There is also
3개의 좋아요
thanks, yes, saw ones for amazon but this is for any link so what would happen:
  1. user posts link
  2. system checks if it’s one of our active affiliate partners
  3. link is amended
2개의 좋아요
thanks looking for something more custom - not ebay/amazon - more any outgoing sites that we have as partners which could be dozens of sites
1개의 좋아요
Thanks Jay, possibly something like this.
I’m in discovery phase for a new brand/site and forum a key component.
we would have dozens of affiliate partners.
so a user may post with a root domain Example.com
or a deep link Example.com/link/link/etc
in every link case we would want to cross check to see if it’s an affiliate partner - and if so change the link to an affiliate (tho still on face of it, showing the clean link - for various reasons, but we’d be clear that we have affiliate links to user).
what do you think
1개의 좋아요
As I said, the theme component that I linked would need to be modified to work for deep links–it was specifically developed not to work for deep links. As a theme component, it works in the browser. This has advantages of not needing to rebake posts when affiliates are added, removed, or changed. You’re welcome to contact me or ask in Marketplace.
A plugin could be better since it wouldn’t be re-writing the URLs in the browser, but it would be more complicated since it would require rebaking posts when a change was made affecting those posts. Maybe $1000 +/- $500?
2개의 좋아요
@pfaffman님이 말씀하신 대로, @Moin이 링크한 eBay 제휴 컴포넌트나 그의 컴포넌트는 요구 사항을 충족하기 위한 맞춤형 #customization:theme-component의 시작점으로 좋은 후보가 될 것입니다.
3개의 좋아요
Thanks so much Jay! Appreciate you coming back and detailing things.
Great it all sounds pretty doable. I’m scoping out the whole biz model for it. If we go ahead, I’ll absolutely contact you.
2개의 좋아요
thanks Dan
2개의 좋아요
